Cooling problem
Old Feb 24, 2015 | 07:06 AM
grumpy365's Avatar
grumpy365
Cooling problem
OK,
(It's NOT the Resistor)
(2004 Mini Cooper with 98,000 miles)
So, a few days ago, I get out of my car and the High fan is blowing.
I find it odd, but don't think a lot about it, but it does it 2 more times that day.
So I search and some said, it was probably low on fluid, and indeed it was a little low, so I add some water.
Well then I start paying attention to the gauge and it hangs out pretty steady in the middle, but I am sitting in traffic and it climbs from the middle to the max in about 15 seconds or less I hear the high speed fan come on and it recovers. the scenario takes 20 to 30 seconds.
I check the low speed fan. I turn on the AC and low speed fan comes on, I pull the low fan relay and high speed fan come on, I THINK that is working right.
This seems to happen more when it is cold and may relate somehow to the heater. I say that because it did it again today and after it recovered , the heat in the car wouldn't really warm.
No light ever came on accept the little light on the top hash of the gauge.
So any ideas?
Cliffs:
Temp runs at temp. In traffic or stopped, the temp intermittently sweeps up and recover. Low fan & High fan seems to be working. may or may not e related to cold outside temperatures.
Old Feb 24, 2015 | 08:18 AM
Helix13mini's Avatar
Helix13mini
The temp gauge stays pegged in the middle for about a 40 degree range which is deceptive. Regardless, your car is overheating unless the high speed fan runs. If your coolant is at the proper level and bled properly, you might have a water pump issue or a semi-clogged radiator. Have you ever flushed your coolant?
Old Feb 24, 2015 | 09:00 AM
grumpy365's Avatar
grumpy365
I haven't had not had the cooling flushed since I had the car.
I don't understand "stays pegged in the middle for 40 degrees". do you mean from the middle to pegged is 40 degrees?
The high speed fan does run, does that mean I am likely OK? I am worried about over heating / warping the head, etc.
Thanks.
Old Feb 24, 2015 | 09:40 AM
Helix13mini
Sorry, I mean the needle doesn't move, even though the temp can be changing within a range of about 40 degrees.
Thanks.
You don't want the high speed fan cycling on and off all the time, it does mean your engine is running hot.
iggi
18
Feb 9, 2026 01:00 AM
Kimolaoha
Jul 5, 2023 01:04 PM
robbiedowns22
Aug 25, 2015 12:20 PM
Lschneider
Aug 21, 2015 02:21 AM
ki7hy
Aug 12, 2015 07:07 PM
