Cutting hood for DFIC
Old Feb 23, 2015 | 10:10 AM
mishanja's Avatar
mishanja
I have recently bought an DFIC by m7 (http://www.m7tuning.com/m7-direct-fl...-dfic-634.html)
So, I was wondering if anyone had experience with cutting hood to install the exit scoop? I saw pictures of couple MINIs here on the forum with exit scoop. Is it something that can be DIY? Or professional help would be the best in this case? Any suggestions would be great
Old Mar 10, 2015 | 08:38 AM
mishanja's Avatar
mishanja
200 views, and no suggestions.... bump....
Old Mar 10, 2015 | 09:10 AM
Saltysalt's Avatar
Saltysalt
for cutting the hood, this is defiantly a measure multiple times, then cut.
first I would outline where the scoop sits with something that can be erased
or
make a cardboard outline of the scoop of where it sits
second or first, im sure you would want to remove the hood, unless the intercooler is already removed.
then you could either drill a hole and use a jigsaw. use a cutting wheel with the best of your abilities. or a rotary tool (dremel) and cut the place where the unit will sit.
then mask the bare metal that you have created with either primer, paint, or some other sealant, don't want to rust!
place the unit in, fasten it the way they want and you should be good to go
**edit** mightycar mods on youtube did something similar to the s2000, they put hood latches in, which would technically be the same process for different parts
Old Mar 11, 2015 | 12:17 PM
isleofbones's Avatar
isleofbones
I agree with everything Saltysalt said. I personally like using a jig saw, using a drill pilot hole for my starting point. Also, I put masking on the bottom of the shoe on my jig saw so it does not mar finished surfaces. I would even be tempted to fully mask the surface to be cut in order to minimize the possibility of abrasions / scratches. Finally, do not push to hard with the drill or jig saw (let the tool do the work) or you will most likely dent, crease or wrinkle the very thin metal. That being said, I definitely think this is an easy DYI for any person who operates with care and precision.
Old Mar 11, 2015 | 02:05 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Honestly if you are asking the question you probably should seek a pro. One screw up will wind up costing you more than the install cost. I'm pretty handy but terrible at the measure twice, cut once thing.
Now if the product comes with a template, then I'd have no hesitation doing it myself. Check and see if that is the case.
Old Mar 11, 2015 | 02:08 PM
mishanja's Avatar
mishanja
Yes, according to m7 there is a template and everything else required in the package
Old Mar 11, 2015 | 02:15 PM
Minnie.the.Moocher
Depending on the tolerance for the cut, it sounds pretty easy. I'm not steady enough with a grinder, so I'd probably use the dremel and a bunch of small cutting disks. Pretty easy to control and make the cuts. Unlike Isleofbones, I'd have a tough time with a jigsaw on a not flat surfaced thing like a hood.
OutMotoring
Mar 3, 2017 06:29 AM
ahorvath
Oct 3, 2015 01:13 AM
M7Speed
Oct 1, 2015 07:05 AM
mini merle
Sep 30, 2015 04:42 PM
BossyR56
Sep 28, 2015 11:33 AM
