New 2002 Mini Owner Flashing Yellow Exclamation Point Questions
Old Dec 8, 2014 | 09:32 PM
Teeto.Miller's Avatar
Teeto.Miller
Hello,
I am a new 2002 Mini Cooper owner. I just picked up my vehicle from the dealership today where all they did was replace the clutch cables.
Everything was fine then this flashing yellow exclamation point with a tire around it started flashing at me.
I checked the manual it said to pull over right away and check tire psi or for a flat. No flat was found but I smelled burnt breaks as if I had just come down a mountain and used the brakes too much.
I turned the car off, restarted the car the flashing light was gone.
I drove about another 3 minutes and the same thing happened.
I checked on all these different forums and everyone says to check the psi or that it may be a wheel issue.
Problem is everyone is talking about this light not flashing and no one else has said anything about the burnt break smell.
Has anyone heard of this?
I thought I may have left the parking break on which may have caused that light to come on and the burnt break smell but I made sure it was off when I started driving again. I noticed there is one level on the ebrake that doesn't make the brake light turn on so I thought it may be that. However, after I made sure to put the ebrake all the way down and the light still came on flashing.
Once I stopped I pulled the ebrake up and put it down several times thinking maybe the ebrake was stuck a little and then drove the car for about 30 minutes on and off the highway to see if turned back on and it didn't. I have since driven several short distances and the smell is not there and the light has stayed off.
Just wondering if anyone out there has run into this and if anyone has info on the ebrake warning lights?
Thanks in advance for any responses anyone has.
Teeto
Old Dec 8, 2014 | 10:13 PM
CornerCarver's Avatar
CornerCarver
If the image above is the warning light you see, it is your Dynamic Stability Control light. Turn the car off to reset or press/depress the button and your problems should be solved. You may have accidentally pressed the button unintentionally without realizing it.
Last edited by CornerCarver; Dec 8, 2014 at 10:18 PM. Reason: Created URL instead of Photo
Old Dec 8, 2014 | 10:53 PM
Teeto.Miller
Not The One
It's not that light. it's an exclamation point with a horseshoe around it that looks kind of like a tire. Thanks though.
Old Dec 9, 2014 | 05:14 AM
JABowders's Avatar
JABowders
Veteran: Army
Responded in your other thread ...
Motor on!
Old Dec 9, 2014 | 05:23 AM
ZippyNH's Avatar
ZippyNH
Short answer..bring it back to the dealer...
Say "its broke, fix it".....
Not you problem if you picked it up and it did it on the way home. Even a cash buy, as is should get you hone....
tr3y003
Oct 22, 2015 10:48 AM
Mini'mon
Aug 16, 2015 04:15 PM
Terry J
Aug 11, 2015 09:39 AM
jrezzo
Aug 9, 2015 10:32 PM
