How do you turn on the A/C?
Old May 21, 2014 | 01:46 PM
Calcutta's Avatar
Calcutta
Hello ev1...
I bought 06' cooper S this past winter and now I have no idea how to turn onn the Air Conditioner. There is the ac button with light but the button cannot be pressed or won't go in. Is it possible that my mini did not come with AC?
thanks...Louis
Old May 21, 2014 | 02:03 PM
Mcameron's Avatar
Mcameron
i dont think you can buy a car today that does not come with AC standard....
and if for some reason it didnt come with AC, they wouldnt have put the button for it in the car.
......im willing to bet your button is just broken/ stuck.......
Old May 21, 2014 | 02:11 PM
pburke's Avatar
pburke
turn down the temperature on the center dial ring around the readout for temp. blue and red arrows to go up or down, and if the fan is blowing (auto will do), you will get AC, provided it's not in need of a recharge.
in the image below it is set to 74F - turn the ring around that number to the left, counter clockwise, to select a lower temperature. Rest is the way mine looks when it's blowing cold:
http://0.tqn.com/d/cars/1/0/R/S/1/ag...enterstack.jpg
Old May 21, 2014 | 02:15 PM
drea-min's Avatar
drea-min
How to turn on A/C
Originally Posted by Calcutta
Hello ev1...
thanks...Louis
On your A/C control push the Auto located on the top left of the control, if the outside temperature is colder than your setting the AC compressir remain off, lower it below the outside temperature by turning the know towards left, 1 click is 1 degree increment, when i turn on my AC i always put the unit on circulation.
Hope this helps
Old May 22, 2014 | 03:38 AM
Calcutta's Avatar
Calcutta
I have the rotary ac/heat system (IHKS).
I think your right Mcameron. I pulled the button out and it pushes back in but i have to pulled it out again. Its clogged pretty good. Ac still not working and the button does not light up. I guess i have to take it apart or take it to a pro.
thx guys
Louis
rob&JCW
Feb 21, 2018 02:41 PM
Supertractor3
Apr 7, 2017 11:16 AM
rob&JCW
Oct 9, 2015 11:12 AM
doug5g
Sep 2, 2015 04:53 PM
Suspension Products
Sep 2, 2015 10:32 AM
