2010 Clubman brakes question
Old Feb 12, 2014 | 02:28 PM
AndesMINI's Avatar
AndesMINI
At around 100,000 miles, the brake fluid service light came on. I asked two reputable mechanics if it needed to be serviced. Each one said that if the fluid is clean & clear, leave it alone - it is, so I did leave it alone. Now, at 103,000, the brake service light is on - fluid reservoir is full, and brakes work fine... Please advise....thanks...
Old Feb 12, 2014 | 04:20 PM
richardsperry's Avatar
richardsperry
It could be the cbs system asking for someone to do something, or one of the brake pad wear sensors is tripped. You need to read the manuals to see what the car is trying to tell you. But really, how hard is it to pull the wheels and have a look? Or just look...
Old Feb 12, 2014 | 04:58 PM
ashchuckton's Avatar
ashchuckton
Change the fluid. It absorbs moisture over time. This leads to a lower boiling point.
Another reason being the fact that the moisture corrodes caliper pistons. It is cheaper to change the fluid rather than corroded calipers.
Old Feb 17, 2014 | 04:56 PM
Slave to Felines's Avatar
Slave to Felines
Best to change it every 2-3 years. You can't necessarily tell that it is not contaminated just because it looks clear. (Though if it is black and nasty looking, it definitely needed changing a while ago!!)
Old Feb 17, 2014 | 05:22 PM
danjreed's Avatar
danjreed
Originally Posted by ashchuckton
Change the fluid. It absorbs moisture over time. This leads to a lower boiling point. Another reason being the fact that the moisture corrodes caliper pistons. It is cheaper to change the fluid rather than corroded calipers.
This 100x
Longjas
Factory JCW Talk (2009+)
Nov 2, 2015 02:28 PM
thebordella
Aug 31, 2015 01:37 PM
Longjas
Aug 24, 2015 06:06 AM
Redhotz
R55 :: Clubman Talk (2008+)
Aug 14, 2015 05:29 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
