Rotating tires
Old Aug 21, 2013 | 04:25 AM
k2at11's Avatar
k2at11
Rotating tires
When one rotates the mini tires should it be front left to rear left and rear left to front left or front left to rear right and front right to rear left?
I never really rotated my tires but I want to start now.
Tnx
Old Aug 21, 2013 | 04:41 AM
cristo's Avatar
cristo
Alliance Member
Depends.
If your tires are directional, you can only rotate on the same sides.
If not, you the recommended way is usually:
r rear to r front, l rear to l front, r front to l rear, l front to r rear,
(or is it the other way around - probably doesn't matter).
Old Aug 21, 2013 | 04:48 AM
k2at11's Avatar
k2at11
Nothing is simple. Now I have to find out if the OEM run flats are directional tires or not.
Tnx for response.
Old Aug 21, 2013 | 06:55 AM
Fly'n Brick's Avatar
Fly'n Brick
The tires have arrows molded into the sidewall. If they're bi-directional the arrows will point both ways. Proper front wheel drive, bi- directional rotation is; front straight back, rear cross left to right - right to left. Directional tires same side only. It all depends on the tread pattern and design purpose of the tire. Most all seasons are 'bi' while performance tires are usually not.
All statements are, of course, conditional based on manufacturer's specifications or the end user's WAG interpretation.
Old Aug 21, 2013 | 07:00 AM
danjreed's Avatar
danjreed
Tnx for response.
IIRC only the GP tires are directional.
I prefer the X method of rotation.
Tires, Wheels & Brakes
Sep 9, 2015 11:08 AM
Sep 3, 2015 02:06 PM
Ntety
Sep 2, 2015 08:39 PM
