valve field problem
Old Feb 19, 2013 | 09:45 AM
ressler's Avatar
ressler
valve field problem
My mechanic says i have a valve field problem caused by carbon build up. He can do the walnut shell service but found oil around new spark plugs. Cost: $3500
says i should trade in car
Old Feb 19, 2013 | 09:49 AM
MINIdave's Avatar
MINIdave
Valve field problem?
Maybe you meant valve guide problem?
What year is your car?
If it's a turbo car chances are it's not a valve guide problem but just the normal direct injection carbon buildup problem, which the dealers charge between $400 and $800 to fix. Maybe take it to your MINI dealer and get a more accurate diagnosis?
Old Feb 19, 2013 | 10:49 AM
ressler's Avatar
ressler
valve field issue
I have a 2008 Mini Cooper Clubman S with 65,000 miles on it
new spark plugs were put in a month or so ago
the mechanic said he found oil wrapped around them
says the carbon issue has led to valve problem
says it will cost $3500 to fix
alex87f
Mar 25, 2017 03:46 PM
Jacob Kenney
Sep 1, 2015 10:22 AM
PEterChoqu
Aug 26, 2015 08:33 AM
HaveATank
Aug 24, 2015 10:26 AM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
