windshield washer won't spray
Old Dec 15, 2012 | 08:39 PM
scouttyboy's Avatar
scouttyboy
I own a 2004 S. My windshield washers are not spraying any fluid, the resevoir is full with windshield washer solution and I hear a humming sound from the area of the resevoir when I try to get the washers to spray. unfortunatley nothing comes out. If anyone has any suggestions as to the fix, please share.
thanks!
Old Dec 15, 2012 | 09:13 PM
MiniR53's Avatar
MiniR53
Did you let the reservoir run empty? If you were trying to use the washer jets without any fluid in the system, the lines are probably all dry, so you will need to allow the lines to fill up before they pump.
Old Dec 15, 2012 | 09:40 PM
reRESERVEDMD's Avatar
reRESERVEDMD
Either that or the pump had been disconnected. It happened to a friend of mine. Spray it for a little while then check under the hood for any moisture.
Old Dec 16, 2012 | 07:13 PM
Slave to Felines's Avatar
Slave to Felines
I have had the jets in other (older) cars plug up with washer fluid residue. I was able to unplug it with a pin.
Old Dec 17, 2012 | 05:39 AM
mini4mo's Avatar
mini4mo
Common problem with any vehicle.
Hobine
Oct 7, 2015 04:52 PM
bahman
Sep 26, 2015 07:38 PM
The Rossness
Sep 17, 2015 03:06 PM
Gen1Parts
Sep 7, 2015 03:50 PM
Gen1Parts
Sep 7, 2015 01:37 PM
