Will I need to reset TPMS when changing to snow tires
Old Nov 16, 2012 | 08:32 AM
t-bear's Avatar
t-bear
Hi All,
I purchased Snow tires on rims when I got my 2007 Mini S from a local mechanic in May.
I am assuming the wheels do not have Tire Pressure Monitors in them and so I am wondering if I am going to get a Warning light when I change them when the snow starts falling?
If I do can I just reset the system?
Old Nov 16, 2012 | 08:58 AM
oldtruckpainter's Avatar
oldtruckpainter
Resetting the system will do no good. The system still will not get a reading if the TPMS is not in the wheels. You will get a yellow warning light on the speedometer. It's very small and easy to ignore after a few days. This is what happens on my car when I put on my snow tires, as I am to cheap to by four more sensors. You will need to reset the system in the spring when you put your regular wheels back on.
Old Nov 16, 2012 | 09:08 AM
richardsperry's Avatar
richardsperry
Or you gould buy a set of sensors and have them installed, and avoid the idiot light.
Old Nov 16, 2012 | 09:14 AM
ViperNL's Avatar
ViperNL
Never mind
Old Nov 19, 2012 | 07:41 AM
Capt_bj's Avatar
Capt_bj
it depends
the TMPS changed mid year on the 07
my 07S uses the old ABS based system - no sensors. You can tell which you have by looking at the valve stems.
If no sensors - yes just do a reset and you are good to go.
If you have sensors, you'll need to buy a set for the winter wheels, or live with the warning light.
woodstudio
Mar 15, 2020 08:28 AM
sprp85
Aug 22, 2015 06:16 AM
col127
Aug 21, 2015 02:11 PM
AoxoMoxoA
Aug 21, 2015 09:15 AM
FLYM1N1
Aug 16, 2015 01:17 PM
