Open the pod bay doors, Hal...
Old Sep 5, 2012 | 10:45 AM
kcrobin53's Avatar
kcrobin53
My manual says that an unlocked MINI should allow the rear hatch to b e opened by depressing the button underneath the handle for a second or two. Mine does not. Is there a trick to that or perhaps it is defective? Thanks!
Old Sep 5, 2012 | 11:02 AM
Angib's Avatar
Angib
If it's a second generation Mini, have you got the setting in the menu that makes it unlock everything from the key fob? The alternative is that the key fob unlocks only the driver's door.
Old Sep 5, 2012 | 11:30 AM
hsautocrosser's Avatar
hsautocrosser
My switch went out and needed to be replaced. However, the button on the key fob has always unlatched the hatch.
Old Sep 5, 2012 | 12:10 PM
wandrur's Avatar
wandrur
Moderator
On the 2nd gen, the button is (only) on the right side, so you have to be sure to depress there.
Old Sep 5, 2012 | 12:22 PM
kcrobin53's Avatar
kcrobin53
Hey thanks everyone. Mine is 2009 so i think 2nd gen. I'll read the manual and see if it tells me how to set the key fob to unlock all doors. Right now it only unlocks the driver's door unless I click again, and then click the hatch button too.
Old Sep 5, 2012 | 12:36 PM
area49's Avatar
area49
On my 2005 R53, you first have to unlock via the inside "Lock" toggle switch, then the hatch will open, (or you can use the FOB),
Old Sep 5, 2012 | 04:28 PM
TiggerGTO's Avatar
TiggerGTO
I had to have the switch replaced on my 2011. It was quite noticeable when the button mechanism under the rubber cover had become misplaced -- it felt like you weren't pressing anything under the rubber. I tried taking it apart, but could only get the assembly off of the hatch that includes the license plate light. I couldn't figure out how to get inside the housing without damaging it. I put it back together and made a service appointment. They fixed it for free under warranty.
Old Sep 5, 2012 | 06:19 PM
kcrobin53's Avatar
kcrobin53
Thx, area49, tried that first. I swear the danged thing opened by hand once. Time to go root out the owner's man'l. But I suspect it's a faulty button.
rtk90
Aug 29, 2019 09:08 AM
molala
Oct 2, 2015 01:53 PM
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
Sep 10, 2015 12:34 PM
Filmy
Sep 7, 2015 08:27 PM
Southern Marylander
Sep 3, 2015 05:46 AM
