Firefighting MINI
Old Jul 7, 2012 | 02:56 PM
lsirois's Avatar
lsirois
Firefighting MINI
I am a firefighter and would like to install some red lights on my new MCS. On my pick-up, I simply have a set of LED lights that sit on the dash. For the MINI, I was hoping for something more concealed and out of the way, but I can't quite see where I can squeeze in any lights other than on the dash.
There must be a few firefighters lurking here. What dod you guys do?
Old Jul 7, 2012 | 04:39 PM
Samui's Avatar
Samui
I did a quick google search. You could grab some visor lights (like these: http://www.extremetacticaldynamics.c...roducts_id=120) and wire them up. I think they would be out of the way and would work fairly well.
Also check out this link: http://www.prestigeemergencylights.com/
Old Jul 7, 2012 | 04:44 PM
Gizmo's Avatar
Gizmo
Not my MINI (Mine is the blue one in the back) but this is pretty cool, even has a big fire department badge on the sides.
Could you somehow mount them behind the grille?
Old Jul 7, 2012 | 05:00 PM
Blackbomber's Avatar
Blackbomber
Not subtle, but maybe use some colored vinyl over your driving lights to mimic the ones on cop bikes.
Then replace bulbs with strobes.
I can't believe I actually suggested vinyl, but those lights look like they'd be too big, plus you already have the driving lamps.
Old Jul 7, 2012 | 10:20 PM
Kirby11's Avatar
Kirby11
Interesting links, Samui! This visor version is compact and looks pretty slick:
http://www.extremetacticaldynamics.c...x.php?cPath=67
Personally I'm entertained by the idea of the Mini for the MINI.
http://www.extremetacticaldynamics.c...x.php?cPath=68
Old Jul 8, 2012 | 06:28 AM
Psquared's Avatar
Psquared
I was going to suggest some small LED flashers in the grill if they will fit. If not, I say go for the lights that go on your visor.
I like the idea of them mounted in the grill, with a switch cleanly mounted inside. Not into the big dash lights anymore!
Anything lower than the grill won't be very visible when you get close to other cars.
http://www.galls.com/search?searchac...2f%2fHideaways
or
http://digitalmagazinetechnology.com...atalog#page=77
Old Jul 8, 2012 | 10:16 AM
firemerc13's Avatar
firemerc13
From: Just south of the White mountains, just north of the lakes region, in other words, Rumney, NH
Funny I should see your post today. I am trying to do the same thing. I bought a dash light, corner led strobes, and grill lights for the front and rear. Hardest part will be making brackets for the grill. I'll post pics if I can when they are all installed.
Old Jul 8, 2012 | 11:53 AM
Gizmo's Avatar
Gizmo
firemerc, your brackets will most likely be different than Isirois's because his car is a 2nd gen MINI.
I may suggest somehow mounting the rear lights on the rear parcel shelf.
Old Jul 8, 2012 | 02:32 PM
lsirois's Avatar
lsirois
A lot of the guys put strobes in their headlights....drill holes and everything. I ordered my Mini with the Xenons, blacked out and clear signal markers....no way am I drilling into those pricy lights. I look forward to seeing what you can put behind the grill....awfully tight in there. I did think about strobes on the driving lights and applying a red film over them. That wouldn't break my heart as much.
Dec 23, 2015 10:36 AM
Dashdog
Aug 10, 2015 06:17 AM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
