Key remote wont start the engine problem
Old Jun 11, 2012 | 02:03 PM
Royyben's Avatar
Royyben
Hey all
I recently bought my dream mini cooper 08
And the 2nd key suddenly refuse to start the engine.
It just can lock and unlock the doors.
Someone can help me out?
My dealer is far far away from me
Old Jun 11, 2012 | 05:46 PM
LarriB's Avatar
LarriB
If you have comfort access, the battery is replaceable, not rechargeable. I'd try and replace the battery, or at least switch the batteries.
I had the opposite problem- doors wouldn't open but the car started. When I brought the car in, they said they had to reset the key. My SA had never heard of it before and said there was nothing I could do.
Good luck.
Here's my post from the other thread:
Originally Posted by LarriB
I took my MINI in for, among other reasons, one of the remote's buttons were not working. The SA noted that the car would start, but none of the buttons would lock/unlock the doors or the trunk. When I picked the car up, the remote was fixed. This is what the invoice said:
"transmitter was placed in hold mode, wherein buttons must be held in order to activate their functions rather than pressed briefly. ... Test plan removed hold mode and asked for verification of operation...."
My SA had never heard of this before. He verified with the mechanic that I did not change some setting to put the key into hold mode, nor could I have have fixed the remote. Nor would the buttons work if I held them down, as noted on the invoice.
Anyone else see this before?
Larry
Old Jun 11, 2012 | 10:24 PM
Royyben's Avatar
Royyben
You think i need to replace the battery?
But how i can open the remote? It looks like the remote can't be open
Old Jun 11, 2012 | 10:49 PM
LarriB's Avatar
LarriB
Do you have Comfort Access? Then the remote has a replaceable battery. If you don't have Comfort Access, then the remote is recharged by the car. Im not saying its the battery in the remote, but that's the first thing to check is you have Comfort Access.
Old Jun 11, 2012 | 10:50 PM
MiniMeep's Avatar
MiniMeep
Is the key one of those with buttons on it or just a plain key?
It sounds like you need to program the key to work with the car, do a search on programming the key and follow the procedure.
Old Jun 12, 2012 | 12:40 AM
Royyben's Avatar
Royyben
I have both remotes 3 buttons ... And if i need to program it pls show me me how cause i didnt find any post.
Tx for your help
Old Jun 12, 2012 | 08:30 AM
AustinS's Avatar
AustinS
To hopefully help clear this up...if you must put the key fob in it's slot to start the car, you do not have "comfort access" and the battery is not replaceable. In that case you will have to got to a dealer.
Last edited by AustinS; Jun 12, 2012 at 12:12 PM. Reason: comfort access not remote access
Old Jun 12, 2012 | 10:01 AM
Royyben's Avatar
Royyben
Im sorry but i didnt understand you
Old Jun 12, 2012 | 12:23 PM
AustinS's Avatar
AustinS
Is your key a fob like this
Does it have to be in the dash slot for you to start the car? If so, you do not have comfort access and cannot replace the battery, it recharges while driving.
Or - can you start the car with the fob in your pocket? If so, you do have comfort access and can replace the battery.
But it sounds like in either case you will need to go to a dealer.
Old Jun 12, 2012 | 01:50 PM
Royyben's Avatar
Royyben
1st thing , tx for helping. 2nd thing ii have the same key u just post here.
U're saying i need to program my key?
Old Jun 12, 2012 | 01:52 PM
Royyben's Avatar
Royyben
And i can't start engine without puting the key inside the slot.
Old Jun 12, 2012 | 02:11 PM
AustinS's Avatar
AustinS
I'm not positive, but I think the key can only be programmed by a dealer.
Then again, I don't understand why the fob would let you start the car, then stop working. I have never had a problem with either of my fobs.
Can you call a dealer maybe they could help you over the phone.
09R56
Nov 16, 2022 10:49 AM
Zettinger
Aug 25, 2015 04:04 PM
skippermini
Aug 13, 2015 06:13 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
