2003 MCS drivers side door lock problems
Old Jul 26, 2011 | 03:50 PM
k_h_d's Avatar
k_h_d
About two weeks ago the interior door handle stopped working. I had to roll down the window to open the door from the outside. Just today the electric door lock stopped working. I can open the door manually from the outside by unlocking the door with a key but I can't open the door from the inside once the doors are locked.
Does anybody have any information on replacing the electric door lock? Also what issue would the inside handle not working be?
Thanks,
Kenny
Old Jul 27, 2011 | 05:30 AM
buddy lee's Avatar
buddy lee
Thanks,
Kenny
I had both problems you're describing with my '03 MCS (back in 2006 though). The door handle was a broken cable that connected the interior door handle's action to allow the door to open (had to be replaced) and the door lock was a burnt-out door lock acuator (had to be replaced).
Luckily, neither repair is super expensive...
Old Jul 27, 2011 | 08:36 AM
hexon's Avatar
hexon
The inside door handle not working is a common problem. Most of the time it's just the end of the cable popping out of its plastic holder. You can reach in and pop it back into place once you've taken the door panel off.
I don't have any experience with your other door lock problem.
Old Jul 27, 2011 | 11:52 AM
BRGPA's Avatar
BRGPA
Do a search for Bowden Cable. There's quite a good write up with photos about popping the cable end back into place. That won't cure the lock or motor problem, but a search using "door won't unclock" should get you some results, too. Good luck.
Old Aug 13, 2011 | 11:47 AM
k_h_d's Avatar
k_h_d
Had to replace the Lock actuator. Problem solved. That job SUCKS with the window guide rails etc...
PrimePower
Aug 16, 2015 06:29 PM
Redhotz
R55 :: Clubman Talk (2008+)
Aug 14, 2015 05:29 AM
messyjesse96
Aug 12, 2015 05:51 AM
PrimePower
Aug 11, 2015 12:51 PM
