belt tensioner bounce/rattle.
Old May 23, 2011 | 06:57 PM
segi's Avatar
segi
hello
A few weeks ago I was driving and the belt snapped, when I was about to change it I saw the crank pulley was broken. I bought an ATI damper and intalled it. Since then the belt tensioner is bouncing/rattling most of the time.(gets worse when AC on and sometimes just dont rattle).
I have a 16% supercharger pulley and JCW belt size.
Any ideas what could be happening?
Old May 24, 2011 | 03:00 AM
HRM's Avatar
HRM
Your tensioner may be bad or the belt is too large. Belt size you want to be using is napa 4060535
Old May 24, 2011 | 06:43 AM
segi's Avatar
segi
I see that your pulley setup is almost the same as mine. Is that the belt size you are using right now?
Ive found this:
NAPA#60535= 1375mm
JCW= 1374mm
Old May 24, 2011 | 01:04 PM
HRM's Avatar
HRM
Ive found this:
NAPA#60535= 1375mm
JCW= 1374mm
Then you must have a bad tensioner if the JCW isn't larger.
Old May 24, 2011 | 02:23 PM
MINI33342's Avatar
MINI33342
The JCW oem belt is indeed a bit larger. Not sure where that info came from. But the 535 belt is the right one for the 15/16% pullies. Anything larger and you will be bottoming out the tensioner.
If the tensioner is bouncing around in all likely hood the damper is worn out. Unfortunately this is not a replaceable part. The whole tensioner assembly will need to be replaced.
Old May 24, 2011 | 04:42 PM
segi's Avatar
segi
The info for the JCW belt came from Realoem, the other from outmotoring.com(dont know if its correct).
I checked the belt today and its starting to worn out with just 3 days and maybe 3 short rides. I think the new crank pulley might not be well installed, or when the belt broke the first time, it damaged something there
Old May 24, 2011 | 05:36 PM
HRM's Avatar
HRM
If the new pulley isn't all the way on, the pulleys won't line up and the belt will get trashed fast.
vulkandino
Oct 31, 2015 08:29 PM
pahg
Oct 5, 2015 11:50 AM
eliseo1981
Sep 30, 2015 07:57 PM
fkrowland
Sep 30, 2015 10:30 AM
daviday
Sep 25, 2015 01:31 AM
