Electrical problem
Old Feb 21, 2011 | 07:47 PM
frankysuarez's Avatar
frankysuarez
Electrical problem
I just installed an MSD Coil in my 2005 MINI. Followed the directions and disconnected the neg from battery. After reconnection everything works fine with the exception of the A/C which doesn't turn on the light and now just blow hot air. I checked the fuses and are OK.
Old Feb 21, 2011 | 08:00 PM
shrimpy
Well, it is pretty safe to assume that the coil it'self did not cause the AC failure. Having said that, it is also pretty safe to assume that if it worked right before the install and did not work right after, you did something to cause this.
Take a look around your work area (near the coil) and see if you possibly disconnected a wire somewhere that goes to the compressor or a pressure switch in an AC line.
This is likely going to be solved by an "ahhh haa" moment
Old Feb 22, 2011 | 12:10 AM
truckboy's Avatar
truckboy
Kindly check the fuse wheather it is burned out or not, secondly check the relay working or not, replace them if found faulty. kindly check wires are corroded or wires with discontinuity
David.R53
Sep 1, 2015 06:51 PM
jesterofatlas
Sep 1, 2015 11:26 AM
Zettinger
Aug 25, 2015 04:04 PM
Terry Gallentine
Aug 11, 2015 03:31 PM
