CAI illegal in CA - Workaround possible?
Old Jan 22, 2011 | 12:03 AM
nics.sd's Avatar
nics.sd
I want to install a CAI in my MINI but I read somewhere that it is illegal to do so in CA. Is there a workaround? Will I still be able to pass smog checks?
TIA.
Old Jan 22, 2011 | 12:07 AM
silhouette88's Avatar
silhouette88
How about keeping your stock airbox so you can swap it when you need to get the smog cert?
JCW intake is also an option if you don't want to go through that "hassle". Good luck!
Old Jan 22, 2011 | 12:12 AM
nics.sd's Avatar
nics.sd
I guess that's an option. My problem is, I'm not a DIY guy so swapping it can be a bit of a problem for me.
Old Jan 22, 2011 | 12:37 AM
silhouette88
Although not as sexy as say, a DoS or DDM intake, the JCW intake isn't a bad product. Intakes for our cars are mostly for sound. Jan @ RMW has suggested the JCW intake makes the best performance gains, at least with his tune. Since you have a new car, and don't really want to install stuff on your own, I think the JCW intake makes the most sense. I got the JCW exhaust (for looks and sound) over the Invidia Q300 (my first choice) purely for the warranty factor. It's not for everyone, but if you like that "big company insurance" thing then it's an option. Good luck!
Old Jan 22, 2011 | 01:43 AM
Eric_Rowland's Avatar
Eric_Rowland
As far as DIY goes, it doesn't get much easier than a CAI. Two torx screws, pop the oem clamp and replace with a standard screw clamp.
If nothing else, contact SDMC or other local club, odds are the install will cost you a beer.
That said, I got mine smogged last year. Can't remember if I had the Madness intake or the Dinan (the latter, I think) and they didn't look twice.
Old Jan 22, 2011 | 06:45 AM
Agarwaen's Avatar
Agarwaen
Dinan is Smog certified, if you can find one. It is also a very good intake to combat heatsoak, as it is quite thick plastic.
Old Jan 22, 2011 | 07:48 AM
C H I C K L E T's Avatar
C H I C K L E T
NM intakes are CARB exempt...
http://www.nm-eng.com/news/26/carb-e...-is-final.html
Old Jan 22, 2011 | 07:50 AM
COR BLMY's Avatar
COR BLMY
K & N (Typhoon) is certified ...
I really think that so many of the CAIs look stock (as long as it isnt Bright Red or something) that the tester wouldn't look twice.
Old Jan 22, 2011 | 07:55 AM
nics.sd's Avatar
nics.sd
Thanks for the replies.
I am actually looking at K&N Typhoon only because my service advisor told me aftermarket intakes will void my warranty except for anything K&N. I almost settled for a drop-in filter!
Old Jan 22, 2011 | 09:51 AM
3pedalMINI's Avatar
3pedalMINI
Legally they cannot void your warranty. Just a heads up they just tell customers that it will because they do not want you to bring in the car for warranty work if you royally screw something up (which IF they can prove that your mod/install flubbed up your engine then they can "void" that part of your warranty. IE: your intake filter fell off and it sucked in dirt and clogged your valves and engine" Then they are not liable.
Old Jan 22, 2011 | 10:28 AM
nics.sd's Avatar
nics.sd
Is that true? Thanks for the information!
Old Jan 22, 2011 | 10:56 AM
gothmdoc's Avatar
gothmdoc
Go with an NM intake.
Old Jan 22, 2011 | 11:14 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I suggest either the JCW or the NM intake. Both will be legal for you.
Old Jan 22, 2011 | 11:15 AM
nics.sd's Avatar
nics.sd
I'll look into it. How is it better than K&N?
Old Jan 22, 2011 | 11:18 AM
nics.sd's Avatar
nics.sd
I read somewhere that you have an installer somewhere here in San Diego. If I buy from you, do you know how much he'll charge for installation?
Old Jan 22, 2011 | 12:04 PM
silhouette88
Absolutely true. Google for Magnuson–Moss Warranty Act for some terrific light reading.
Last edited by silhouette88; Jan 22, 2011 at 12:08 PM. Reason: Mistakenly made it sound like it was my suggestion. Black11 gets credit.
Old Jan 22, 2011 | 01:17 PM
Maugre's Avatar
Maugre
nics.sd
Just want to give you a little encouragement, if you can change a tire you can change your intake yourself. They all come with good instructions, and you need some basic tools. Save some $ and learn to DIY, might even find out it's fun. Take care and good luck.
Old Jan 22, 2011 | 01:23 PM
nics.sd's Avatar
nics.sd
Originally Posted by Maugre
nics.sd
Thanks, Maugre. I think I can do it, I'm just worried I might break something. But everyone's been telling me that an intake should be easy. I'll give it a shot!
Old Jan 22, 2011 | 01:53 PM
WayMotorWorks
Vendor
If you bought an intake from us he would prob do it for the price of lunch.
Old Jan 24, 2011 | 09:00 PM
COR BLMY's Avatar
COR BLMY
wow ... got to give it to Way Motor Works , for always getting their name out there
The OP is in San Diego and Way is in Atlanta ... ohhh .. yes but they will install for free just a 4000+ mile round trip ...
Old Feb 3, 2011 | 09:39 PM
nics.sd's Avatar
nics.sd
So I think I've made my decision. I think I want to go with the DoS CAI. I figured I can just swap the OEM intake come smog check time.
What do you guys think? I'm still a little bit worried about the warranty though.
Old Feb 4, 2011 | 07:13 PM
COR BLMY's Avatar
COR BLMY
hey "nic.sd"
Really the swap is easy . and most smog techs wouldn't look.
If your sig tells me you have a '11 you have years till that is a worry.
As far as warrantee goes ...search for more info here and also search "magnuson moss warranty act aftermarket" your aftermarket BOV that you already have will raise more eyelids than a CAI
Old Feb 4, 2011 | 07:22 PM
minimike21's Avatar
minimike21
Dos intake is awesome! I wouldn't worry about voiding a warranty... Keep us updated
Old Feb 4, 2011 | 07:30 PM
ofioliti's Avatar
ofioliti
Why would a CAI be illegal? I did a quick search and all I read are laws against modifying the emissions system. The intake just filters the air entering the engine, so why would that be a problem? (I just want to understand the logic behind the law.)
Old Feb 4, 2011 | 08:15 PM
nics.sd's Avatar
nics.sd
DoS CAI it is! After doing lots of research, I believe this is the right way to go.
I already emailed Clint. Now all I have to do is wait!
