Shifting
Old Dec 31, 2010 | 08:12 AM
Rigby2011Cooper's Avatar
Rigby2011Cooper
Shifting
Hey everyone!
I was wondering how all of you shifted your MINIs, and if anyone had any insight on how our MINIs react to certain types of shifting.
Let me start it out ... I have found that my MINI has a bit of a rough shift if I take her up to a higher gear in the 2500RPM range, and it is super smooth when I take her to around 3500RPM. It also seems as though I get a rougher shift if I ease the clutch out after my shift as opposed to smoothly BUT QUICKLY releasing the clutch.
Has anyone had similar results? Fast and hard shifting VS. Slow and steady shifting?
Just a side note, I am new to driving a MINI and brand new to driving stick. I actually have only been driving stick for one month, so any tips would be greatly appreciated.
My take offs are still a bit rough as well. It feels like I am being too easy on the gas.
I look forward to your comments!
Old Dec 31, 2010 | 10:35 AM
onenun's Avatar
onenun
I've found that because the MINI has such a wide power band I never have to use all the gears to get up to speed. Usually it's 1-2-5, but i'm finding that 1-3-5 is a little smoother.
Old Dec 31, 2010 | 10:44 AM
nickydicky13's Avatar
nickydicky13
when i first started driving manual i was doing and the car was acting like everything you describe. i drive an 02 justa tho. i assume the new ones arent much different. 1st gear is always the hardest to get down smoothly, that will take some time to master. i usually shift into second around 15-20mph 3k-4k on the tach. it really depends how you are driving at the time. if i want to go fast and have some fun ill shift real quick and get my foot back on the gas as soon as i can with out rocking the car.
honestly it really depends on how you decide to drive the car. MINIs fun zone is up in the higher RPM range but as long as youre not redlining every shift you dont have much to worry about.
the best advice i can give you is just to practice and practice some more. learn the car, learn how it handles in different conditions and just practice shifting. it comes, dont worry about rocking the car or anything just relax and have fun. manual takes a while to learn and get down perfect.
bit of winter advice. remember lower rpm will help more in snow and slippery conditions. the other day i found myself going through 5 inches of slushy crap in 3rd gear going 20mph.
also check out the clubs im pretty sure they have a few big clubs out near youre area.
WELCOME TO NAM AND WELOME TO MANY YEARS OF JOY AND HAPPINESS =D
happy motoring
Old Dec 31, 2010 | 11:42 PM
Fly'n Brick's Avatar
Fly'n Brick
Balancing engine speed to engaging the clutch is a balancing act that must be mastered. Easing the clutch can lead to slipping the clutch leading to excessive wear which leads to dollars out of the pocket. In addition, the only time the left foot should be on the clutch pedal is while shifting. Do not rest your foot on the pedal ever while the engine is turning over. Do not sit at a stop signal with the clutch disengaged. Take it out of gear and put that left foot flat on the deck 'till ready to drive away. On hills, you may need to use the hand brake (takes a little practice but worth the effort) while you take your foot off the brake to get yourself going without rolling back into that duece and a half with the winch on the front bumper. The other wear point on the system is the throwout bearing. You want that to last a long time, so take care not to abuse it.
Back in the day when driving a manual was part of driver's ed, we learned all that and more in an Army surplus '49 chevy sedan.
Old Jan 1, 2011 | 05:53 AM
Alexander!'s Avatar
Alexander!
As far as the hand brake on hills, my mini has hill assist. This means while you take your foot from the break to the gas (while on the clutch) the car will hold the brake. It makes it a bit easier to keep from rolling back while learning the clutch on a new car. OR if you're like me you'll panic the first time it happens and almost stall ... . For shifting, I find that around 3.5k out of first tends to be pretty smooth. Smoothness is more a matter of experience than what RPM you change gear at. I wish I got to learn on a MINI - sound like a fun way to go!
Old Jan 1, 2011 | 06:08 AM
HRM's Avatar
HRM
There is no real set rules. If you are going downhill and not excelerating, your shift is different than when you are getting on a highway. Time will help you figure out what is appropriate and when.
I often skip gears depending on the situation. Downhill in a 30mph zone, 4th or even 5th may be perfect.
Old Jan 26, 2011 | 05:45 PM
Quadrivium10's Avatar
Quadrivium10
I'm a newbie to Minis and to manual shifting. I just bought my 2006 MCS this past Saturday and it is the first stick shift I have ever driven. I just want to say thanks to everyone for the tips - very helpful. I live in the city and there are plenty of stoplights, hills, "dueces" that sit right on your back bumper, rush hour, and construction. Gotta learn fast or else.
Old Jan 26, 2011 | 07:32 PM
gothmdoc's Avatar
gothmdoc
+1 for hill-assist!, LOVE this feature...my stick-savvy fiance' was sitting my car the other day, asked "why doesn't your car roll at the stops..." - I was like "MAGIC!"
Old Jan 27, 2011 | 04:53 AM
Quadrivium10
Bare with the newbie question....but how can you tell if you have hill assist? Is it a seperate option available on Mini's or....??? That would be pretty sweet to have when you live in a city that is notorious for its hills.
Old Jan 27, 2011 | 05:34 AM
CaptainSteve's Avatar
CaptainSteve
I'm fairly new to the MINI experience, so not sure when Hill Assist became standard, if its only with certain packages.
You can tell very easily if you have this feature, by finding a hill, probably best on a side street or parking lot, or some other low traffic area. Have the car pointed up hill, with the car stopped, put foot on brake, push in the clutch and place tranny in 1st ger, let go of break. If you don't start rolling backward, you have hill assist.
Note that Hill assist only engages for a few seconds, so if you hold long enough you will eventually roll back, if you don't step on the gas and let out the clutch.
Old Jan 27, 2011 | 06:00 AM
Jeremy1026's Avatar
Jeremy1026
Moderator
Hill assist is on all 07+ MINIs with a manual transmission. Its just a few lines of code programmed into the computer.
Old Jan 27, 2011 | 06:30 AM
Quadrivium10
Since it's code, would it be possible to take a Mini to the dealer and have it programmed into the computer on an '06?
Old Jan 27, 2011 | 06:33 AM
Jeremy1026's Avatar
Jeremy1026
Moderator
Probably not, since the 06 has a completely different ECU map from the 07.
Old Jan 27, 2011 | 06:35 AM
Quadrivium10
Gotcha - that makes sense. I figured as much but thought I would ask anyway.
Thanks for explaining all of that - good to know.
Old Jan 27, 2011 | 09:07 AM
ellcapitan's Avatar
ellcapitan
One more tip: Since brakes are cheaper than clutch, always hang on to the gear you're already in when decelerating for a distant anticipated stop, etc, for as long as the car will continue to run smoothly...usually bringing the rpms down to just above idle-speed, before de-clutching (pressing the clutch pedal) and shifting to neutral. Combined with using the brakes, the engine-braking will assist you in smoothly slowing the car down, and at least you're still in gear for instant speed resumption if conditions unexpectedly change (light turns green, etc).
This, as opposed to popping it in neutral at speed and wasting all that "freewheeling" inertia on the brakes, then, if not stopped, having to "jam" it into the appropriate gear to resume speed (bad for the syncros...assuming you're not rev-matching). Leaving it in gear makes it far easier on the transmission if you have to select a lower gear to resume acceleration before you're actually stopped. This practice, BTW, tends to be a hallmark of the novice stick-shifter, LOL. Don't get into this lazy habit to begin with, and you won't have to undo it later!
What's even worse, many people down-shift when decelerating, to get even more engine braking. While it may feel gratifying to them that they're saving wear on their brakes, all this does is needlessly double the wear on the clutch! ($$) FWIW, you should only down-shift to maintain speed going down a hill, or if rapid acceleration is anticipated.
Beyond that, I pretty much agree with everything said above. Sorry if I sound like an owner's manual.
Old Jan 27, 2011 | 11:54 AM
gothmdoc's Avatar
gothmdoc
+1 on this, I used to down-shift to help with braking but then realized its increase wear on the clutch is much worse than changing pads. Hill-assist lasts for ~2 seconds on my 09 MCS.
Old Jan 27, 2011 | 01:38 PM
minimike21's Avatar
minimike21
i downshifted on my 02 and never had a problem with my clutch? am i just lucky????
Old Jan 27, 2011 | 05:08 PM
Quadrivium10
This forum has really helped me a lot with learning the "to dos" and "not to dos."
Here's a question for you experienced shifters...
When you're going down a fairly steep hill, not wanting to downshift (like it says below), traffic is stopping rather quickly, and you don't want to grind gears, what should you do? Oh an if you brake, your rpms are going to go low enough that you'll stall or get the lugging feeling. What should you do? Just asking because there are plenty of roads where I live that have instances just like this and I want to avoid damaging my clutch and tranny at all costs.
Old Jan 27, 2011 | 05:21 PM
gothmdoc's Avatar
gothmdoc
What do you mean grind gears?, depress the clutch and put it in neutral, then slam on the brakes!
Old Jan 27, 2011 | 05:28 PM
MINIxB's Avatar
MINIxB
It's on automatic Mini's too.
Old Jan 27, 2011 | 05:57 PM
Quadrivium10
I've been chatting with folks where I live/work that have manual transmissions and they said that when they first started driving a stick shift that they would actually hear the gears grind because they missed or didn't push the clutch down all the way. I'm just asking 1) when that would happen and, 2) what would cause it so I don't do since I'm new to shifting.
Old Jan 27, 2011 | 05:59 PM
Eddie07S's Avatar
Eddie07S
Great post
A couple of point I found with my Mini. One thing that I found is that the clutch engages and disengage very high on the peddle (does that make sense? with the peddle a long ways from the floor). It is almost like the gears want to be spinning to engage smoothly. It is a timing thing and with a little flick of the wrist it can be very smooth, almost like you haven't even shifted at all. Very nice when it comes off right. But the car definately doesn't like to shift smoothly if I wait to reach the floor before I shift.
When it is cold, I will run it in 1st at about 2k for a bit to warm things up before shifting. This helps a lot.
As someone said, there is a lot of power throughout the RPM band. With the S that is true; don't know about the Just'a. I often skip gear. I like 1-2-4-5 around town; shifting at 2k. But it also loves to rip up to 4k at times
Down shifting should always be done by matching the engine speed to the road speed. There should be no jerkyness when you let the clutch out. A good thing to learn is to heal and toe (brake while pressing on the gas and letting out the clutch with the engine speed matched). But that can wait.
All in All shifting a Mini is the best of any car around. Looking forward to lots of years of rowing through the gears
Old Jan 27, 2011 | 06:08 PM
Quadrivium10
Originally Posted by Eddie07S
Great post
Thanks so much Eddie07S!! I'm glad you knew what I was trying to ask when I didn't know how to word it. That makes sense what you said. Just to make sure I understand...the MINI S shifts better when the clutch isn't all of the way down, right? Just trying to make a short cheat sheet of this thread in my head for when I'm driving.
Old Jan 27, 2011 | 06:18 PM
minimike21's Avatar
minimike21
no you should always depress the clutch all the way down... it just catches the gear higher up than some cars... meaning when you depress the clutch and shift then let it out it catches the gear further out...
Old Jan 27, 2011 | 06:23 PM
Quadrivium10
Okay, I think I gotcha now. So, press the clutch completely down, then let it up quickly (not dragging it out). I've been shifting quite successfully since I bought my MINI. I've had one person teach me and another tell me tips. I just want to make sure that I have the proper info for shifting a MINI. It does seem like it shifts smoother when you left off the clutch quickly.
Thanks again for everyones help and patience. This truly is helpful
