Suspension question
Old Aug 25, 2010 | 08:44 PM
vettestripes's Avatar
vettestripes
Suspension question
Hi,
I'm new to this forum and planning to take advantage of $199 leasing deal.
Earlier this year, I tested drive a 2006 Mini cooper S and the drive was so hash ... even worse than my 2001 4Runner.
I love Mini Cooper S. Does all MC S will be rough like that?
Would the standard MC softer?
Thanks so much in advance!
-Mike
Old Aug 25, 2010 | 09:55 PM
BensMini's Avatar
BensMini
The MINI is a sports machine and it's suspension is designed for such a designation. It is not soft and will not be otherwise no matter which model you select. If it is too harsh for you then I would suggest that you look elsewhere.
Old Aug 25, 2010 | 10:10 PM
hsautocrosser's Avatar
hsautocrosser
See threads on runflat tires.
Old Aug 25, 2010 | 10:28 PM
vettestripes
I'm owning a vette with full suspension but does not have run flat anymore so it drives much smoother than MC S.
Look like it maybe the run flat issue.
Thanks the post above for the answer! Not sure if I can find anyone with non-runflat to do a test drive.
Old Aug 26, 2010 | 03:58 AM
JimR56JCW's Avatar
JimR56JCW
Where are you? I'm sure there is a member near you with non run flats.
Old Aug 26, 2010 | 08:36 AM
vettestripes
Hi,
I'm in DFW, texas.
So MC S and regular one got the same suspension?
Thanks so much guys!!!
Look like I will go to dealer later today!
-Mike
Old Aug 26, 2010 | 09:47 AM
Calz's Avatar
Calz
There is a difference between the base Cooper suspension and Sport suspension. Both are very stiff. And yes if you have run flats it makes it even worse... especially if they are Pirelli Euphorias or the Goodyear Eagles.
Old Aug 26, 2010 | 10:21 AM
quikmni's Avatar
quikmni
There also was a JCW suspension option that lowers and stiffens the car. The JCW suspension has red springs. The JCW suspension with run-flat tires is harsh.
twistedimages
Sep 19, 2024 04:13 AM
silence2-38554
Nov 12, 2015 09:39 AM
Kahnfucious
Aug 15, 2015 08:43 PM
Emnotek
Aug 13, 2015 05:47 PM
nomar116
Aug 10, 2015 11:24 PM
