A basic guide to Spark Plugs.
Old 09-07-2020, 04:48 PM
Lex2008's Avatar
Lex2008
Lex2008 is offline
I never did like bending the side electrode or tapping it is This is way more precise.
  #177
Old 11-10-2020, 06:16 AM
Forte5t's Avatar
Forte5t
Forte5t is offline
So trying to read through this thread and I'm really wanting to change plugs on my car when it arrives. Its a 12 coupe jcw and has 91k miles. Which copper plugs should I go.to? I tried brisk when I had a fiat abarth and they fouled pretty bad after a few thousand miles. Rather run NGK if I can.
  #178
Old 11-11-2020, 04:26 PM
OCR's Avatar
OCR
OCR is offline
Forte5 -
Just a note to think about.
IF...the spark plugs actually "fouled" (black sooty garbage), that's NOT...the spark plugs fault. That's either an ECM mapping problem or other engine problem..!
Mike
  #179
Old 11-30-2020, 05:35 PM
Forte5t's Avatar
Forte5t
Forte5t is offline
Originally Posted by OCR
Forte5 -
Mike
It was the plugs fault lol. I swapped back to my NGK plugs and ran perfect with no issues.
I am about to buy plugs for the Coupe but trying to figure out which plug to use and what gap for them. I am going to order coil packs also since mine are rusted looking
haygood (09-11-2022)
  #180
Old 11-30-2020, 05:43 PM
Lex2008's Avatar
Lex2008
Lex2008 is offline
Maybe plug wasn't getting hot enough to burn off the soot.
  #181
Old 12-01-2020, 03:12 PM
yesti's Avatar
yesti
yesti is offline
We're both brands the same heat range? If not that would explain it.. Is your car stock tune? If so you need the stock heat range and not something colder.
  #182
Old 03-28-2021, 04:59 PM
bisnitch's Avatar
bisnitch
bisnitch is offline
@Oldboy Speedwell
I need an NGK Ruthenium plug with with the PSPE (Projected Square Platinum Electrode).
I was wondering how you verified that the appropriate size for an r56 was FR7BHX-S (92400)?
I haven't had any luck verifying what's the correct part number or gauging.
  #183
Old 03-28-2021, 05:35 PM
Oldboy Speedwell's Avatar
Oldboy Speedwell
Oldboy Speedwell is offline
Originally Posted by bisnitch
@Oldboy Speedwell
Mine is an '06 R53.
ngk.com is a little wonky in that department...
...what I did is find the one that they "verify" and just go 1 heat range colder:
Like,
if I type in the plugs I've been using lately which have been doing really good,
and thoroughly documented by many others as good ones too,
are these which NGK tells me are incompatible:
But they are kosher!
NGK will list the BKR6EIX as compatible,
but not the 7.
Rather odd,
but I guess it's a liability thing on their end where the legal department requires them to strictly adhere to OE spec?
  #184
Old 03-28-2021, 05:57 PM
bisnitch's Avatar
bisnitch
bisnitch is offline
Yeah, I have an 2007-2011 r56 so here is what the NGK Part search tool was showing but it wasn't clear about the turbo or DOHC option.
  #185
Old 03-28-2021, 07:49 PM
Oldboy Speedwell
That chart indicates only for the R50/52/53 with the W10 or W11 motors...
...punched in 2010 MCS to see what they list,
all they have are three available options,
and one of those is discontinued!
Tried to do a cross reference based on that but couldn't find anything.
Gave a quick look into other cars that use the Prince engine that may happen to have alternates that people have found,
still didn't find much...
...but I kinda dig the DS3 -
May be best just to write or call NGK and ask them.
  #186
Old 03-28-2021, 08:33 PM
bisnitch's Avatar
bisnitch
bisnitch is offline
I took your advice and messaged NGK on their site. I guess the entire internet will learn when I do too. You wouldn't think that it'd take over half a day to figure out the best spark plug...
Oldboy Speedwell (03-29-2021)
  #187
Old 03-29-2021, 06:06 AM
bisnitch's Avatar
bisnitch
bisnitch is offline
  #188
Old 03-29-2021, 06:29 AM
Oldboy Speedwell
Well, that answers that.
Cool that they got back to you so quickly.
Did you just want to try them because you like the design?
I do and plan on trying them at next plug change interval.
  #189
Old 03-29-2021, 06:59 AM
bisnitch's Avatar
bisnitch
bisnitch is offline
I'm digging deeper since something doesn't smell right. I think that their part search tool is broke. Nothing like giving tech support to the leader in the industry, lol.
  #190
Old 07-05-2021, 12:34 PM
ripple57's Avatar
ripple57
ripple57 is offline
Super helpful-- thank you!
  #191
Old 09-20-2022, 08:25 PM
mountainhorse's Avatar
mountainhorse
mountainhorse is offline
OBS... Did you ever run the FR7BHX-S Plugs, on the R53?
Oldboy Speedwell (09-21-2022)
  #192
Old 09-21-2022, 06:19 AM
Oldboy Speedwell
I did indeed, put them in several months back.
They've been performing very well!
Will inspect them soon and see how they look after 4 months.
mountainhorse (03-29-2024)
  #193
Old 09-21-2022, 11:11 AM
mountainhorse
Thanks for that OBS 👍
I was surprised by the price … only about $8.50 each on them from reputable distributor…
I think that’s what I’m going to run on the stock 2006 JCW … seems like a more durable alternative and may have some other benefits
Oldboy Speedwell (10-11-2022)
  #194
Old 10-11-2022, 01:24 PM
Oldboy Speedwell
Did oil change today and pulled plugs to check them, can't really say much except that they've been performing well and appear A-OK after inspection and I think that the protruded tip is a great design.
Gapped at 0.29" and they're still there.
I haven't experimented much with various gap sizes,
but wondering if I should?
Any input/opinions regarding gap size is most welcomed!
Thanks.
A couple of pics:
The following 2 users liked this post by Oldboy Speedwell:
Lex2008 (10-11-2022), mountainhorse (11-27-2022)
  #195
Old 03-29-2024, 05:04 PM
mountainhorse
OBS, thank you !!.. Those look to be great... I didn't see your reply above with pics...
I have mine still on the shelf... Car has been parked in the warehouse for a LONG time now... Got all my service items sitting there ... just need the disposable wrench time for my unpaid labor for myself... UGH.
Thank you all again for this wonderful thread and the time you've put into it.
BTW: Still only $8.72 each for the Ruthinium .... FR7BHX-S NGK STOCK NUMBER 92400
https://www.rockauto.com/en/moreinfo.php?pk=9779948
Cheers !!
  #196
Old 04-21-2024, 01:26 AM
Russ68's Avatar
Russ68
Russ68 is offline
My Coop is a 2006 R53 cooper s running JCW airbox and a couple of other little tweeks but i dont think shes mapped (that said she is rapaid so i regularly ? that) would i be right in thinking i would be better to run plugs more designed for the JCWs rather than standard cooper s ones for a bit better performance, mpg and general well being of my fantastic little daily driver (im uk based if that makes a difference)
O by the way fantastic to read a great section on this great forum
charrigan
01-30-2022 01:48 PM
cboyd1
03-01-2016 04:58 AM
AlexQS
05-26-2013 01:12 PM
goaljnky
03-22-2006 04:46 AM
Petrich
05-20-2003 05:44 AM
Quick Reply: A basic guide to Spark Plugs.
