so whats the deal with this oil drain plug...
Old Jul 2, 2010 | 08:47 PM
djomlas's Avatar
djomlas
broke 4 attachments and 4 13mm sockets.
it didnt freggin move at all, like loctite from hell or something...
i even used WD40 to get it to move, nothing...
Old Jul 2, 2010 | 09:23 PM
Crashton's Avatar
Crashton
Use a 6 point high quality 1/2 socket. If you are breaking sockets they must be pretty poor quality steel. Use the right tools, because if you don't you'll end up chewing the drain plug up. It is very common for those drain plugs to be over tightened.
Old Jul 3, 2010 | 03:57 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Yeah the 1/2 socket or box end wrench fits much tighter and you not round off the plug.
When I first purchased my MINI, it was on so tight, the oil pan/plug had to be heated up a little with a torch to remove.
I have heard some speedy oil places use air impact wrenches to tighten them up
Old Jul 3, 2010 | 04:10 AM
JAB 67's Avatar
JAB 67
Once you get it off, replace with Fumoto drain valve.
Old Jul 3, 2010 | 08:27 AM
firenewt's Avatar
firenewt
+1 on that
Kevin
Old Jul 3, 2010 | 08:57 AM
djomlas's Avatar
djomlas
i got it off, thank god. i was already reading on alternative ways to get it off.
after i posted this i was researching some more and this morning did it with 1/2 and it came off.
i will order the valve for next oil change, too late now
thanks for speedy replys guys
Old Jul 3, 2010 | 09:03 AM
Crashton's Avatar
Crashton
Glad you overcame the over-torque monster.
Old Jul 3, 2010 | 09:59 AM
CRoth's Avatar
CRoth
I changed my oil today and had a similar issue. I first tried to remove it with an open end wrench with no luck. Since I always torque my bolt to spec I hasd my torque wrench handy and removed it with that. I couldn't believe how tight it was. They're only suppose to be torques to 18 ft/lbs..
Nice to hear you got the job done.
Chad
Old Jul 3, 2010 | 07:08 PM
Fatherdeth's Avatar
Fatherdeth
Get that oil drain valve. It's worth the money!!
Old Jul 3, 2010 | 07:24 PM
grueinthebox's Avatar
grueinthebox
Call me paranoid, but I have concerns about having one of those protruding directly out of the bottom of the car... Something in the road hits that wrong and that's it for the engine.
Old Jul 4, 2010 | 03:52 PM
Hawkeye's Avatar
Hawkeye
I replaced the OEM oil drain plug with a regular ( I think it is 16mm) oil pan drain plug. I use a six point closed end wrench to remove it when changing my oil. It only sticks out of the pan by less than a quarter of an inch.
Old Jul 5, 2010 | 07:11 AM
Fatherdeth's Avatar
Fatherdeth
First gens only. Ours are hidden, but the second gens hang down below the engine thus causing more chance of it gettng hit causing damage.
Old Jul 5, 2010 | 07:25 AM
CRoth's Avatar
CRoth
I had the exact same thought. The only way I would use one is with a skid plate because my car us so low.
woodstudio
Mar 15, 2020 08:28 AM
5904
Aug 27, 2015 10:00 PM
TBRoye
R55 :: Clubman Talk (2008+)
Aug 24, 2015 08:41 PM
Aug 19, 2015 12:51 PM
