Ethanol or "Pure" Gasoline, and How to Tell the Difference
Old Jan 15, 2010 | 09:41 PM
  #26
Oxybluecoop's Avatar
Oxybluecoop
Ive tested the gas at all the local stations here in south Charlotte(shell,citco,bp/amoco/exxon and texaco) and all contain between 8-10% ethanol. Not surprising since NC doesn't require any pump labels and all the fuel comes on the pipeline. I did get 6 gallons of the texaco 100 octane today and it contains no ethanol. Too bad it costs 8 bucks a gallon.
Old Jan 16, 2010 | 07:13 AM
  #27
HalAC's Avatar
HalAC
Originally Posted by fishbone
US posts AKI at the pump, not RON like Europe. AKI is RON/MON so are you sure it was RON you were looking at? That is rather low actually, and it would not qualify as premium-grade gas in Europe, by a long shot.
Ooops, my bad! I've corrected it in my previuos post.
Old Jan 16, 2010 | 07:32 AM
  #28
Mishka's Avatar
Mishka
Can't you find regular gas with no ethanol? I believe only mid-grade blends it, the "bottom" 87-grade should be unblended, pure gas.
Missouri recently passed a law requiring all gas (if I remember correctly) to be ethanol blend, so she may have a hard time finding gas without ethanol.
Old Jan 17, 2010 | 04:15 AM
  #29
cristo's Avatar
cristo
Alliance Member
If regular unleaded is 87 octane with 8-10% ethanol, I wonder what the quality of the
gasoline would have been without the ethanol added.
edit: forgot that if you don't use ethanol, you use something else (MDPE, etc.) to up the octane.
Old Jan 17, 2010 | 06:55 AM
  #30
ScottRiqui's Avatar
ScottRiqui
Exactly, although out of curiousity, you can figure out the octane rating of the base gasoline stock before the ethanol was added (assuming no other additives added along with the ethanol.)
The AKI of pure ethanol is about 100, and the AKI of the blended mixture is 87. Assuming 90% gasoline / 10% ethanol, you get:
(0.9 * X) + (0.1 * 100) = 87
X = 85.5 AKI
So ethanol is a pretty effective octane booster, although its lower energy density does offset some of the benefits.
Old Jan 17, 2010 | 07:41 AM
  #31
miniclubman's Avatar
miniclubman
ALL grades? 87, 89 and up? Then what's the point of 87? You gotta love government.
10% ethanol blend is a requirement in many areas. It's in gasoline to help clean the air.
This is probably not an issue in Nebraska, but it's an important issue on Long Island, and if a 10% blend helps keep the air cleaner that's O.K. with me.
Prior to ethanol, the oil companies used an additive called MTBE, which has polluted our aquifers after leaching out from leaky gas station tanks, and is causing major problems with drinking water quality. Ethanol doesn't have this issue, so it's a much better choice.
Old Jan 17, 2010 | 08:07 AM
  #32
LowCountry S's Avatar
LowCountry S
the ethanol hasn't leeched out yet;the MTBE has had years to work it's way into the aquifer. The premium gas here (93 octane) has ethanol (up to 10%) also according to the pump stickers.
Old Jan 17, 2010 | 08:25 AM
  #33
miniclubman
Apparently, MTBE is much nastier stuff compared to ethanol, and it's banned in NY, and many other states.
It's cost gas refiners millions and millions to clean up the pollution mess, and most have switched to ethanol, which also happens to be a better oxygenator than MTBE.
Old Jan 17, 2010 | 08:31 AM
  #34
ScottRiqui's Avatar
ScottRiqui
True, but ethanol is still better than MTBE, even if it does leach into the aquifers. Concentrations of MTBE as low as 40 parts per billion can cause problems with drinking water, and some cities have found their water supply polluted to the tune of 600 parts per billion or higher.
Ethanol is just ethyl alcohol - the same stuff that's in alcoholic drinks, so we know a lot more about its effects, and it's harmless up to levels a LOT higher than MTBE.
Old Jan 18, 2010 | 10:24 AM
  #35
Dr. Pepper's Avatar
Dr. Pepper
Originally Posted by Robin Casady
You gotta love agri-business lobbyists.
Actually, MTBE was a result of oil industry lobbyists. They owned the patents on MBTE and did not want to use ethanol because they would have to pay ADM and the like to use it. Within 3 years it was evident that MBTE was a major poison in our water supply. Hence Big Oil was forced to switch. Ethanol was originally added to boost octane after they stopped using lead, which was poisoning people and plants. Ethanol is much safer though not perfect.
Old Jan 18, 2010 | 02:32 PM
  #36
Robin Casady's Avatar
Robin Casady
My comment was in response to Fishbone blaming government for adding ethanol to 87.
While ethanol might be the best octane booster for gas, using it as a alternative fuel has many problems.
With current technologies, it takes more oil to create ethanol than the ethanol replaces.
USA corn farmers diverting their crops from food production to energy production has led to food shortages in many places.
Brazil is the world's largest producer of ethanol. They are cutting down rainforests to plant sugarcane for ethanol. This is having an adverse affect on the local climate, and may cause desertification in that area.
Old Jan 18, 2010 | 07:03 PM
  #37
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by ScottRiqui
...one of the requirements for a "top tier" retailer is that their gas must have between 8% and 10% ethanol, in *all* grades of gas, at *all* of their retail locations.
I tested the Shell gas I put in Artoo today. Caldwell NJ, but I suspect that Shell is consistent in NJ.
8%.
///Rich
Old Jan 18, 2010 | 07:13 PM
  #38
ScottRiqui's Avatar
ScottRiqui
8%.
///Rich
That's good to know, especially since NJ is one of the states that doesn't have pump labeling requirements for ethanol content.
Old Jan 19, 2010 | 06:51 PM
  #39
MINIxB's Avatar
MINIxB
That is, unfortunately, a legitimate concern. Can't you find regular gas with no ethanol? I believe only mid-grade blends it, the "bottom" 87-grade should be unblended, pure gas.
89 with 10% ethanol here ends up being cheaper than the straight 87. Of course now that I have 2 FI cars I don't even look at those 2 grades.
No. All the gas stations around here have up to 10% ethanol.
Old Feb 4, 2010 | 09:32 AM
  #40
Rixter's Avatar
Rixter
Well said Robin. Ethanol is pure government meddling.
BTW the 94 octane Chevron in my parts advertises that it contains no ethanol
Old Feb 20, 2010 | 11:19 AM
  #41
TomLINY's Avatar
TomLINY
Somebody tested the gas at many stations labled "up to 10%" and found a significant number actually had as high as 15%. That's what concerns me, and it's likely to happen any time the ethanol becomes cheaper than the gasoline. This can happen due to the incentives that are given to ethanol producers.
Also, it makes no sense that we can't get ethanol free gas for our boats and other products designed prior to ethanol laws.
Burkee52
Electrical
Sep 18, 2015 11:12 AM
Klenk
GP Talk
Sep 16, 2015 11:29 PM
HogWldFLTR
Sep 8, 2015 05:25 AM
larryd96
11
Sep 8, 2015 05:01 AM
