Clear Bra did its job
Old May 22, 2008 | 08:53 AM
OPC's Avatar
OPC
RATTUS Deserticus
Ok, so 11days into MINI ownership & the clear bra stands up & takes the proverbial bullet for the front end. The result is the paint is fine, but the shield itself is torn & scrunched up in an area about the size of a dime right under the port side headlight. Unfortunately, the damaged vinyl looks white-ish and is pretty visible.
The bra (not sure if it is 3M) was dealer installed a couple of days after purchase. I have not contacted them for options yet. I first hoped to get opinions from NAM.
What are my options here? Have that whole section of clear bra replaced? Somehow touch up the damaged area - like a patch? Live with it?
Old May 22, 2008 | 09:17 AM
thulchatt's Avatar
thulchatt
see if the dealer will replace but don't patch. I would guess that would look worse than the damage.
Old May 22, 2008 | 09:19 AM
BlimeyCabrio's Avatar
BlimeyCabrio
I have a couple of divots in mine and live with it... only option for me was replacing the whole section, which is $$$....
Old May 22, 2008 | 09:30 AM
OPC's Avatar
OPC
RATTUS Deserticus
Yeah, I was going to contact the dealership after this weekend's road trip to ask about options. The MINI is going in for other warranty work in a couple of weeks anyway, so we'll see if they have any recommendations short of dishing out a bunch more $$.
I also thought I'd see if I have any luck smoothing out the material & getting it to re-adhere. Just to reduce the visibility.
Old May 22, 2008 | 10:00 AM
BlimeyCabrio
You can hit the affected area with a heat gun (on low) or hair dryer to warm it just a bit (or just park it in the sun for a while), then smooth over it with the back side of a spoon (the round smooth side) to work it down and work air out, etc... not sure what you're working with damage-wise... but that may help you.
Old May 22, 2008 | 10:09 AM
OPC's Avatar
OPC
RATTUS Deserticus
Great idea, thanks. I don't own a heat gun, but I live in greater Phoenix area so sunshine is not a problem.
Old May 22, 2008 | 10:11 AM
BlimeyCabrio
Watched the clear bra installer do that to some imperfections on mine... have done it myself since then with good results...
Old Jun 17, 2008 | 08:03 AM
OPC's Avatar
OPC
RATTUS Deserticus
Follow-up:
So I finally got around to visiting the dealership and I pointed this out to my SA. Turns out best they could offer was to remove & replace the damaged section. It was a little pricey, but looks pretty good.
Filmy
15
Jun 6, 2023 06:27 AM
molala
Oct 2, 2015 01:53 PM
Car Care Products
Sep 22, 2015 06:47 AM
Sep 18, 2015 02:44 PM
Ryephile
Detailing 101
Sep 16, 2015 06:32 AM
