Oil Change Oils
Old Apr 25, 2008 | 06:46 PM
rrcaniglia's Avatar
rrcaniglia
Oil Change Oils
I went to buy Royal Purple for my first oil change and found it has an API rating of 'SL'. The MINI manual states the oil should be 'SM'. Yet there are a host of people posting that they use and love Royal Purple. I'm concerned about warranty.
Can anyone help shed some light on the implications of going with SL instead of SM?
R
Old Apr 25, 2008 | 08:43 PM
javelina1's Avatar
javelina1
R
go with anything that is both ACEA A3/B3 and BMW LL-01, and you'll be fine.
Old Apr 25, 2008 | 08:53 PM
AstroBlackS's Avatar
AstroBlackS
Royal Purple 5w40 is SM I believe. That is what I recently switched to, and I love it.
Old Apr 26, 2008 | 07:27 AM
cristo's Avatar
cristo
Alliance Member
Correct. Here is the page that gives API grades of their oils.
The 5W30 is SL.
http://www.royalpurple.com/motor-oil-pp.html
Old Apr 26, 2008 | 12:06 PM
rrcaniglia's Avatar
rrcaniglia
Thank you very much. The store I visited had the 5W30 SL. There was no 5W40 on the shelf. I'll find out where I can get it and go with that.
Thanks again, all.
R
Old Apr 26, 2008 | 06:22 PM
miniclubman's Avatar
miniclubman
For the Clubman, MINI recommends their own brand oil, and two grades of Mobil1, 5w30 and 5w40. There are many, many posts on the forums debating the "best" oil, and all sorts of Euro and U.S. specs and standards, but I'll stick with an oil brand and viscosity specifically recommended by the manufacturer.
Old Apr 26, 2008 | 07:07 PM
Ancient Mariner's Avatar
Ancient Mariner
I think the basic difference between 'SL' and 'SM' is that SM no longer has zinc in it. The zinc is very, very good for protecting bearings under load but why it was removed, I have no idea.
-skip-
Old Apr 26, 2008 | 07:18 PM
rrcaniglia's Avatar
rrcaniglia
I have seen folks talk about the A3/B3 rating and the BMW LL-rating, but my owner's manual only specifies weight and SM. And I'm intrigued by the Royal Purple advertising and NAM member testimonials, so if their 5W40 is rated SM, I think I'll try it.
Old Apr 26, 2008 | 09:03 PM
ScottRiqui's Avatar
ScottRiqui
-skip-
Zinc is bad for catalytic converters, so the API has been gradually lowering the allowable zinc levels over the years.
That being said, the zinc is only there as an "extreme pressure" additive, to act as a last line of defense if the oil film has gotten so thin that you're having metal-to-metal contact in the bearing surfaces and other interfaces in the engine. If you change your oil before it's broken down too badly, the lowered levels of zinc shouldn't make any difference in the long-term health of your engine.
Old Apr 27, 2008 | 11:49 AM
Ancient Mariner
Thanks for the geat info, Scott. Makes me feel more comfortable with the "M" rated oils. I change mine at 5-6k miles, so oil break down has never been a worry.
-skip-
Old Apr 28, 2008 | 06:05 PM
rrcaniglia's Avatar
rrcaniglia
Can you believe I'm having to order Royal Purple 5W40? It appears that no one but me in Northern Alabama wants it.
Old Apr 29, 2008 | 05:14 AM
bmackinlay4353's Avatar
bmackinlay4353
IMHO, I would stick with a Major Brand Motor Oil IE: Mobil 1. And since it is recommended by Mini if you have warranty issues you are safe Bill
Old Apr 29, 2008 | 05:23 AM
thulchatt's Avatar
thulchatt
I can believe it. I am in Chattanooga and while the cost of living is low here the access to some products is also low. At least the internet has made that less of a problem.
Old Apr 29, 2008 | 05:26 PM
rrcaniglia's Avatar
rrcaniglia
Well, since RP meets the owners' manual specs, why would I expect a problem unless the label is Xeroxed and pasted on with Elmer's?
R
Old Apr 29, 2008 | 07:06 PM
miniclubman
rrcanaglia - I agree. MINI specifies any fully synthetic 5w30 or 5w40 motor oil rated "SM". If Royal Purple meets those specifications, and you like the brand, you certainly wouldn't have any "warranty" issues. Specific brands of oil are recommended, not required. Besides, "Royal Purple" sounds much more exotic than "Mobil1" or "Castrol".
Old Apr 29, 2008 | 07:43 PM
rrcaniglia's Avatar
rrcaniglia
Ever notice that exotic sounds like it ought to be the opposite of erotic, but the two seem to go together? I like exotic stuff, like the MINI.
Old Apr 29, 2008 | 08:10 PM
RaceFace's Avatar
RaceFace
I'm rollin' RP 5/30 in the Clubman. I run that in all my vehicles.
Kimolaoha
Jul 5, 2023 01:04 PM
woodstudio
Mar 15, 2020 08:28 AM
Colt45Magnus
Jul 14, 2019 06:18 PM
patpatpat
Aug 27, 2015 07:51 AM
Lex2008
Aug 16, 2015 08:33 PM
