No Gas
Old Oct 11, 2007 | 10:01 AM
miniGarfield's Avatar
miniGarfield
No Gas
Check this out!:impatient
I'm so lazy to put gas but I always make it to the gas station
Old Oct 11, 2007 | 10:05 AM
lilruffcat's Avatar
lilruffcat
omg! lol what really happens if you don't make it though? i heard you run out of gas with your mini and its bad juju
Old Oct 11, 2007 | 10:37 AM
CR&PW&JB's Avatar
CR&PW&JB
I've had my range indicator down to "6" and I thought I was nuts.
YOU are the man. Sorry... YOU are the WOMAN.
Old Oct 11, 2007 | 10:42 AM
goldcountrymini's Avatar
goldcountrymini
You should never run it down that low. There is a reserve in the MINI so when you run out, you really didn't run out.
Old Oct 11, 2007 | 10:49 AM
NMgokart's Avatar
NMgokart
I got to -13 on a club run one time....
Long way between exits here in the desert.
Old Oct 11, 2007 | 10:50 AM
bamatt's Avatar
bamatt
I made it to 8 once & I was terrified. That is the only time I have ever gone below 35
Old Oct 11, 2007 | 10:53 AM
goldcountrymini
I never get below 35 either... My wife drives and coasts into the gas pumps
Old Oct 11, 2007 | 11:00 AM
lotsie's Avatar
lotsie
What will happen if you run real low on fuel is that the car will go into limp mode first, then shut down shortly there after. Hopefully this happens before the injectors run dry, because then bad juju does happens; hard to re-prime the injectors if they run dry.
The MINI does not have a reserve per say, just an ECU that hopefully does not let it run dry of fuel.
The other reason for not running the tank down that low is that any crud in the tank is more likely to get drawn into the fuel lines.
Mark
Old Oct 11, 2007 | 11:10 AM
Edge's Avatar
Edge
AdMINIstrator
Uh, not in the way you think.
Yep.
The so-called "reserve" isn't really a reserve. What they mean is that when you see the little warning light (or, in the case of a 1st Gen MINI with Nav, when the last fuel gauge light turns red), you have just entered "reserve" territory... 2.1 gallons left, if I recall correctly.
It's silly to even call it a reserve. A warning light at 2.1G is not the same as an actual reserve tank!
Old Oct 11, 2007 | 02:25 PM
miniGarfield
I NM mini! Are you coming to our "4 corners run" with us???
So how did you get it to -13??????
And Yes I start panicking when I get it down to like 5 and more when it goes back and forth from 5 to 0 and back up to 5, 6, or 7 then back down to 0 ...I'm trying not to go that low but sometimes my lazyness and running late to work will do it.
Old Oct 11, 2007 | 04:30 PM
goldcountrymini
Edge - you're right... on running out of gas. Correct me if I'm wrong, but you still cannot drive at that point. It's saving the engine from larger problems
Old Oct 11, 2007 | 04:44 PM
diabolik!'s Avatar
diabolik!
got mine down to 7 and it completely ran out of gas.
Old Oct 11, 2007 | 08:53 PM
miniGarfield
wow down to 7 and it died??????????????????????
That's not good!!!!!!!!!!!!!!!!!!
I guess I won't let it go that low anymore.............sorry I've been so bad to my baby I don't want it to get sick one of these days :( Ya'll must think I don't like my mini :(
Old Oct 12, 2007 | 06:20 AM
scuzzlepook's Avatar
scuzzlepook
Lowest I've been down to was 9 miles on my way back home from MTTS. Thank god for downhills and coasting! I was sweating bullets thinking that I wasn't going to make it to the nearest gas station - to boot in the desert & 110+ degrees outside...
Old Oct 13, 2007 | 08:43 AM
lotsie's Avatar
lotsie
I don't think the OBC is all that accurate, even less so when fuel is low. I seldom let mine get below a 1/4 tank. When I was comuting 100+ miles a day in the wilds of Manitoba, I never let it get below a 1/2 a tank. Getting stranded out on the highway at -35 F or C is not a fun thing
Mark
Old Oct 13, 2007 | 06:15 PM
humcmcel's Avatar
humcmcel
A long term consequence of letting the tank get that low is that the fuel pump is in the gas tank and is cooled by the fuel. If you repeatedly let the gas get that low the pump will over heat and fail. Then you have the expense of replacing said pump.
Old Oct 13, 2007 | 06:20 PM
1QukMINI's Avatar
1QukMINI
I have been down below the 0 to the dotted lines twice. I have never had a problem that I knew of, and can say there was alot of praying involved getting to the gas station....I didn't mean to, just didn't notice I guess. I try to really pay attention to it now. It's that getting used to the gauges being in the middle thing. Still, I know it's probably not good for something...
Old Oct 13, 2007 | 06:21 PM
lotsie's Avatar
lotsie
Yup, forgot about that one. I don't get the letting it run down low game
Mark
Old Oct 14, 2007 | 12:20 AM
DrkSilver163's Avatar
DrkSilver163
I also have made it to the dashes, beyond zero territory, lol...(---)<--thats what it looked like.
Old Oct 14, 2007 | 02:44 PM
miniGarfield
I would've totally fricked out and passed out if it had gotten to (---)
That's never happening to me, I hope!
Old Oct 14, 2007 | 07:19 PM
Longboard110's Avatar
Longboard110
Ive ran mine to 0 a few times with no problems, I think right now Im at 3. I hate going to the gas station
Old Oct 15, 2007 | 10:01 AM
70spop's Avatar
70spop
Have you put gas in your car yet?? You must be getting REALLY low by now.
scfiveo
Sep 27, 2019 02:27 PM
PsychoRallye
21
Feb 17, 2019 06:08 AM
OutMotoring
Mar 3, 2017 06:29 AM
riff42
Sep 22, 2015 03:07 PM
mini_mike237
Sep 21, 2015 08:42 AM
