General Discussion Competiting with the new MINI on track or at a SCCA Solo event.
Question for those with wheel stud conversions.
Old Sep 27, 2005 | 02:26 PM
goin440's Avatar
goin440
Figured this would be the best place to post because the racers' would know best.
My studs keep backing out even with red thread lock. The allen key design doesn't allow one to "torque" without twisting the key or even grinding the allen head round. Mine are about 2yrs old and I originally used an air-impact to tighten the lugs nuts until recently.
Coming out of winter and changing to the "summer" wheels, I backed about 6 of the 16 studs out because the stud corroded and the nut "welded" itself tight. I called the vender who said the air-impact knocked the anti-corrode coating off (I didn't tell him I used an air impact). So I ordered replacements and haven't used the impact since then.
I decided to rotate the tires for even wear and backed out 3 more studs, two of which were new. I used anti-seize on the orginal studs too and it appeared to have quickened the corroding, so no more anti-seize either.
What am I doing wrong?
Is there a brake hub with a "press-in" stud available? (as opposed to the screw in type)
G1HQ
Dec 7, 2015 02:23 PM
MINI VINI
Oct 13, 2015 08:57 AM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
Mini'mon
Aug 16, 2015 04:15 PM
ki7hy
Aug 12, 2015 07:07 PM
