General Discussion Competiting with the new MINI on track or at a SCCA Solo event.
Scrub Radius
Old Aug 21, 2005 | 09:50 AM
zack_S_moore's Avatar
zack_S_moore
Scrub Radius
Anyone know what the stock scrub radius is on the MCS's?
Does a 45mm offset wheel push it from negative to positive?
Same outer diameter tire. Thanks.
Zack
Old Aug 21, 2005 | 02:11 PM
namwob's Avatar
namwob
Throw a little kitty litter on the garage floor. park on top of it & turn the wheel back & forth. Mark the outside edges of your contact patch on the floor. Back-up. Need I say more?
Old Aug 21, 2005 | 02:35 PM
zack_S_moore
I'm more interested in knowing the actual numerical value.
Then, I can ballpark the effect of certain wheel offsets, and what the threshold is before the scrub radius turns positive. Thanks.
Zack
Old Aug 21, 2005 | 07:17 PM
namwob's Avatar
namwob
If you know your offset now & own a ruler, this will be the real data, plus more accurate given the additional squat of the suspension with your weight & added or removed weight. For an example, camber & toe varies alot betweed Minis but they shouldn't. Better than kitty litter. Do it on concrete pavement, roll back & measure off tire.
Old Aug 21, 2005 | 07:20 PM
zack_S_moore
The real data bit makes sense, but I'm not sure how I can interpret the markings as which wheel offsets will begin to create positive scrub radius values.
I'm obviously ignorant of this technique.
And, wouldn't some of the movement you're talking about measuring be associated with the caster? Thanks.
Zack
Doc Pain
Mar 10, 2021 04:50 AM
09R56
Oct 12, 2015 09:04 PM
theblackfalcon
Oct 11, 2015 09:49 AM
Nicefeet
Sep 27, 2015 11:14 AM
muddflapp
Sep 20, 2015 03:55 PM
