General Discussion Competiting with the new MINI on track or at a SCCA Solo event.
Aim Solo DL /2DL questions
Old Aug 22, 2021 | 01:29 AM
Dcraft's Avatar
Dcraft
A couple of questions for those that are running one of these in their car. Where and how are you mounting it in the car? Which are you using OBD2 or CAN connection? If using CAN where are you splicing into the wiring? Aim suggests right behind the tach on the steering column, just wondering if those wires are more easily accessed further down under the dash if available? Also anyone have pictures of their install? Thanks!
Old Aug 22, 2021 | 08:23 AM
DavidPinAZ's Avatar
DavidPinAZ
I have a 2021 GP3 and I'm not sure which Mini you have, so this info might or might not apply to you. I have mine mounted on the backside the digital display using a custom kydex bracket (see the attached pics). I have it mounted there because in the GP3, its really difficult to see what gear you're in when at the track. I have the Solo2 setup so that gear is the most prominent bit of info that shows.
As for wiring, I had to use a CAN connection. For some reason, in this car, the Solo2 would not pick up *any* data via OBD2. None. We tapped the CAN connection under the passenger side footwell, because that was the best place to get to the wires. The good news is that with CAN, I get *so much data*!! ​​​​​​​
Wee Bonnie Lass
53
Feb 7, 2016 05:12 PM
MtyMous
Classic Mini Talk
Nov 15, 2009 10:28 AM
grillhands
Electrical
May 20, 2008 04:19 PM
Mini2na
Jan 10, 2008 10:03 PM
R56
Sep 3, 2007 03:11 AM
