General Discussion Competiting with the new MINI on track or at a SCCA Solo event.
Another brake setup thread!
Old Mar 17, 2014 | 10:04 PM
nismo4life's Avatar
nismo4life
So I'm trying to get the car ready for my first track day. I've had my mind set on doing the R56 calipers & carriers upgrade along with the larger 294mm rotors in the front. The HPDE is going to be at Lime Rock and I will be running a worn in set of NT01's. What do you guys recommend for a pad that I can use on that track, yet still live with on my daily commute?
Main concern is the first corner, the rest won't be that hard of braking I imagine. Car is an R53 with a few bolt ons so I feel its only adequate to upgrade the brakes since I've upgraded the suspension, grip, and acceleration of the car by quite a bit over stock.
Old Mar 18, 2014 | 06:01 PM
S-Driver's Avatar
S-Driver
I think you may here from Eddie soon, he has a set of Wilwoods and 12.2" rotors for sale, maybe. But they were on an R56....
Someone will probably steer you towards CarboTechs but I am a HAWK guy but I swapped mine out at the track so no help to you..
I'll be interested in hearing your lap times at LRP...
Old Mar 18, 2014 | 08:01 PM
nismo4life's Avatar
nismo4life
Looking to keep cost down so I wanted to stay away from aftermarket BBK's. Figured the upgrade was cheap since even brand new calipers are only $270 for both with carriers!
What do you run at the track?
Old Mar 19, 2014 | 07:04 AM
daonlyillwiz's Avatar
daonlyillwiz
Get a set of hawk hp plus pads for the fronts and ss brake lines and you should be ok with the stock brakes. If you really wanted you can also get a set of slotted rotors as well.
Old Mar 19, 2014 | 10:43 AM
v10climber's Avatar
v10climber
Pretty sure this pad doesn't exist. Maybe a HP+ but they're pretty noisy on the street and wouldn't stand up to repeated hard braking with the forces the NT01s are going to generate. Obviously it depends on how fast you are but my recommendation would be to buy a set of track pads and get used to swapping them. The dedicated pads will last much longer and be cheaper in the long run. Instead of buying 4 sets of "compromise" pads you can buy one set of street pads and one set of race pads that will last just as long.
Old Mar 19, 2014 | 06:37 PM
Btwyx's Avatar
Btwyx
My theory would be to go with stock until you find you need otherwise. Main thing is to make sure you have fresh brake fluid, it should have been flushed in the last three months.
Both of us run on track, so we're at least twice as hard on brakes as most people. We went over 4 years and 17 events on OEM pads before wear became a problem. As a single driver your first time out, I'd be surprised if you made measurable wear on the pads.
When OEM pads weren't good enough we tried EBC YellowStuff next, they're a lot harder wearing than OEM, and they just as quiet.
Old Mar 19, 2014 | 08:25 PM
S-Driver's Avatar
S-Driver
I've been on a break for a couple years while my car is being built. But I ran Hawk DTC70 pads up front using Wilwoods, and stock rear pads.
I've run both Hossiers and NT01's...at LRP.
woodstudio
Mar 15, 2020 08:28 AM
bjcarter2
Aug 31, 2015 04:03 PM
thebordella
Aug 31, 2015 01:37 PM
Bruce/Fl
Aug 28, 2015 11:59 AM
