General Discussion Competiting with the new MINI on track or at a SCCA Solo event.
First Track Day Pointers! Good for noobs!
Old Jul 10, 2012 | 10:04 PM
BoostCzaR53's Avatar
BoostCzaR53
I picked this up from another site, miata forum, and tailored it slightly to Mini Coopers. Works well for simple first track day things and such, it proves to be helpful for those guys figured it would transfer here.
The Mini Cooper (any year) bone stock is a great car to take to the track. There are however a few items that need to be added to insure your safety and a good time.
First is a decent helmet, most hpde groups will let you run a motorcycle helmet (m2005), an auto racing helmet is accepted everywhere (sa2005/sa2010). The nice thing about a sa rated helmet is that you can use it later if you move up to time trial or wheel to wheel racing. Make sure it is comfortable, so you might want to try it on first. If not they can be ordered from many places like...
SafeRacer - Auto Racing Safety Equipment, Auto Racing Gear, Auto Racing Helmets, Auto Racing Suits
Auto Racing Safety Equipment - Head & Neck Restraints - Racing Seats - Helmets - Fire Suits
The easiest way to ruin a track day is failing tech. Make sure your car is in decent condition for the track. Most org's will have their tech sheet up on their website.
Sample Tech Inspection Sheet! CLICK HERE!
The next easiest way to ruin a track day is to have crappy brakes or fluid. Make sure the temp rating on the fluid is higher for track duty like Motul or ATE. Make sure to do your clutch fluid while your in there.
Motul RBF600 Brake Fluid
Brakes are also very important, there are many choices out there that will normally fit the bill. Stay away from pads that offer little benefit over something from autozone I.E. ebc green stuff, hawk hps, etc. Some pads like Cobalt Friction XR will work fine with rotors that have old pad material on them making it cheaper to just switch them before the track day. Some offer very little rotor where or corrosive dust and can be drivin on the street like Carbotechs XP line, though they do require fresh rotors. Don't cheap out on pads or fluid, it will bite you later.
See Forum Vendors for these!
Rotors might be required if yours are in bad shape or if your running something like carbotech pads. The cheapest rotor is fine for 99% of the guys going to the track. Pick them up locally from any autoparts store.
Discount Auto Parts Catalog - Partsgeek.com
The next weakest link will be the tires you are on. There are many opinions on which is best for what. Most hpde type groups won't let new guys on the track unless you have decent tread. If you do decide to take your all seasons or low end tires out there just remember that they will probably only last 1 track day before they are toast. If you want to put a tire on that can serve dual duty street/track look for lower tread wear ratings and larger blocks of tread. Some examples of these might be Hankook RS3, Bridgestone RE-01, Kuhmo XS, Federal 595RSR, Dunlop Star Spec, Nitto NT05, etc. Try to stay away from more aggresive tires like Hoosiers, Toyo RA1, Nitto NT01 until you have a decent amount of track time under your belt, you'll know when your ready.
These items will make your track day a blast without breaking the bank. Getting on track is the next part. Go to youtube and watch videos of people running the track your going to. After picking someone to run with that has a beginners group. Make sure you bring some basic tools for rotating tires, checking psi, tightening hoses, etc. Bring lots of water, snacks, sunscreen, long sleeve cotton shirt and jeans, and good shoes. Also make sure that you run very little if no antifreeze at the track. You will ruin everyones day if you dump it out due to a blown hose on one of the corners. There are also some things to remember so that people don't hate you after your session.
full tank of gas
grab an instructor
listen to the instructor
check your mirrors
give point bys quickly
drive in your limits
no red mist
be humble, no one likes a cocky newb
Last but still very important, use the search function on this forum. Almost any question you have has been asked and answered 35 times in the last year. You could build an entire podium finishing race car without posting a single question if you read enough. 99% of you will not have anything ground breaking to offer. Make sure to update your lap times in the sticky and post youtube footage for critique.
Kimolaoha
Jul 5, 2023 01:04 PM
squawSkiBum
Oct 2, 2015 09:21 AM
tylewis
Aug 18, 2015 06:53 AM
Mini'mon
Aug 16, 2015 04:15 PM
ki7hy
Aug 12, 2015 07:07 PM
