General Discussion Competiting with the new MINI on track or at a SCCA Solo event.
Which CarboTech Pads?
Old Feb 20, 2010 | 02:29 PM
howsoonisnow1985's Avatar
howsoonisnow1985
I was debating which CarboTech compound to run for track days, between a XP10 Front/XP8 Rear or a XP12 Front/XP 10 Rear. Right now I got the Hawk HP Plus on R53 JCW brakes, which is an Auto-X and supposedly for HPDEs but I get near complete failure occasionally due to fade. What pads do you do guys run? Any suggestions?
BTW: Just got the Pegasus catalog and ran across a new brake fluid, the ProSpeed Motorsport RS683 Xtreme Performance Brake Fluid anyone heard of it? It has a 683 Dry Boiling Point and 439 Wet Boiling Point.
Old Feb 20, 2010 | 06:22 PM
S-Driver's Avatar
S-Driver
Read thru this thread....
https://www.northamericanmotoring.co...ce-needed.html
You might find some useful info in there. I don't run CarboTech pads so I can't help you..
Old Feb 21, 2010 | 04:19 AM
minimarks's Avatar
minimarks
12's and 8's here.
Old Feb 21, 2010 | 02:57 PM
howsoonisnow1985
Yeah thanks I did read that, LOL, actually that thread is what started my own debate between the 12 and 10 pads for the fronts. I was leaning toward the XP10 fronts and XP8 rears cause I figure I could also run as street pad. I am very lazy to switch pads out, even changing wheels bothers me. I know I would probably leave the XP12 pads on after a track day until the proverbial "next weekend" But I am questioning if the XP10s will suffice.
Old Feb 22, 2010 | 08:18 AM
slinger688's Avatar
slinger688
I have been running XP 12 (F) and XP 10 (R) on the stock r56 MCS rotors and calipers but I have the JCW brake ducts for cooling. The choice of XP10 and XP12 on the front depends on the temperature of your rotors and pads. I run about 550 degrees F so I could use either XP12 or XP10.
You should test your brake rotor temp on the track and that would indicate which pad you should be using. If you do not get the XP 12 pads up to operating temps go down to XP 10s. If the XP 10s are too hot, go up to XP12s.
Old Feb 22, 2010 | 08:09 PM
howsoonisnow1985
Decisions
Originally Posted by minimarks
12's and 8's here.
So how that work out for you?
Any fade?
Stock or JCW brakes?
Air ducts?
Guess if I get the XP10/8 combo and if need be I can change fronts to XP12 and keep the 8s in the back. Then keep the 10s for street? (GP now more a weekend car)
Old Feb 22, 2010 | 08:32 PM
minimarks's Avatar
minimarks
Works great! JCW brakes with no brake ducts yet. Now I do have a complete rotor/pad set for the track and a different rotor/pad set for the street. Gave up on compromising, this way I'm good to go at the track or street!
Old Feb 23, 2010 | 06:55 AM
cct1's Avatar
cct1
howsoon, it also depends on your tires...
If you're running high performance street, XP10/XP8.
If you're running R-comps, XP12 on fronts, XP10's or XP8's on rears.
I'm running XP12's on the fronts this year, I'll start XP10's on the rears from last year--still have a fair amount of pad on them, and also try XP8's. I have a feeling XP12/XP8 is probably the best combo (for me anyway)...
Old Feb 23, 2010 | 09:54 AM
bthayer23's Avatar
bthayer23
XP12f/XP8r
TSW MDM with Sneed ducts
dunlop star spec tires
do it. =)
Old Feb 28, 2010 | 09:57 AM
howsoonisnow1985
Thanks ya'll for the input.
Old Apr 28, 2010 | 01:58 PM
timver's Avatar
timver
last Friday @ Thunderhill (4/23)
Hey Howsoon...just another datapoint...
I'm running an R53 with the JCW brake kit up front with Kuhmo XS 215/45-17's...and a few other mods (with RMW tune) getting me up to 213HP/192tq
Last Friday 4/23 was 77 degrees at Thunderhill all day...I was running the XP10's in front and the XP8's in the rear.
the XP10's did fade on me a couple of times coming into turn 14 (from about 95mph to 60-ish? mph)....so I can't say I'm completely happy with them. I need to get the XP12's for the front to see if I'll be sticking with carbotech. Also, they squeal like hell on the streets if not heating up right, so my vote is "no" for street driving (at least for me). FWIW I don't think the rears really matter, those look fine.
btw I have pix of the XP10's and the rear XP8's after my one track day if you're interested...
hope this helps
timver
FatherG
Oct 3, 2015 05:06 PM
little egg
Oct 2, 2015 11:19 PM
Tires, Wheels & Brakes
Oct 1, 2015 02:50 PM
Oct 1, 2015 12:18 PM
Oct 1, 2015 08:55 AM
