P0015 Code
Old Mar 29, 2016 | 02:22 PM
Beau B's Avatar
Beau B
P0015 Code
My 2011 CM ALL4 threw a P0015 code today after getting gas.. it has thrown a code before but always cleared before I could get home to hook up my reader. The car is well maintained and has 117k miles on it.. any thoughts or suggestions, should I replace the cam sensor or take it in to get the timing checked.. from searching that is all I could find, but no one ever followed up with what the issue was.. thanks in advance!
Beau
Old Mar 29, 2016 | 03:17 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Possibly Vanos sensor? Are they original, maybe clogged. Mine were bad at 35000 miles. The newer versions have screens to keep them clear of debris. Worth pulling and checking.
Old Mar 31, 2016 | 05:54 PM
Beau B's Avatar
Beau B
Well dropped car off at dealer tonight.. as I was driving the check engine light went off twice for a few minutes than came back on.. fingers crossed it is the sensor, vanos, or timing tensioner.
Old Apr 1, 2016 | 09:06 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Could be VANOS as P0015 with MINI FC code 0x2D61 is VANOS, exahust: Closed-loop control fault, position not reached. 0x2845 is 'B' camshaft position timing over-retarded (bank 1) and 0x2D60 is VANOS, exhaust: closed-loop control fault, camshaft sticks. Depending on which one you have I've seen VANOS, skipped timing, or camshaft position sensor as the culprit. Report back with your findings!
https://www.northamericanmotoring.co...-retarded.html
https://www.northamericanmotoring.co...ith-p0015.html
888.280.7799 | 6am - 5pm PST
Old Apr 1, 2016 | 05:36 PM
Beau B's Avatar
Beau B
Thanks for posting those links.. I searched but did not come across thoses.. I will report back when I hear something in the morning..
Old Oct 29, 2020 | 10:18 AM
HasAnMTBProblem's Avatar
HasAnMTBProblem
Black-eyed-Purple-Mini S
Jul 21, 2016 06:35 PM
maxedmini
Mar 23, 2016 01:11 PM
Mike Miller
Mar 8, 2016 12:41 PM
PDirector
Mar 8, 2016 08:53 AM
chazen
Feb 29, 2016 09:30 PM
