Brake noise
Old Mar 10, 2011 | 06:24 AM
Jerry Fikar's Avatar
Jerry Fikar
Brake noise
I took my 2009 JCW with 6000 miles into the dealer with brake noise. Best I can decribe the noise is that it sounds like drum brakes with worn out shoes.I also have a squeek when I use them in reverse. The noise is less after they warm up a bit but still there. I have the Brembo brakes.The dealer says their fine and the noise is due to Bi-metalic pads. I know they work better when warmed up, but I think the noise is exsessive. Has anyone run into this situation .I told them to check the right rear rotor as it looked like it had more than 6000 miles wear. They said it's fine.
Jerry
Old Mar 14, 2011 | 01:57 PM
Nimrandir's Avatar
Nimrandir
wrong area.. this is the Countryman JCW
Old Mar 17, 2011 | 10:50 AM
03mini-S's Avatar
03mini-S
Jerry
If you want a response from someone with a JCW R57 then you need to be in the correct forum. You won't find an answer in the Countryman one since there aren't any JCW's at this time.
cheers
Old Jul 22, 2011 | 01:13 PM
ghamma's Avatar
ghamma
OK, so the original poster doesn't have a Countryman to ask about, but I do. And since the posting has already been made, I thought I'd pull it back to the CM.
I only have about 3,000 miles on my CM4 but I've noticed the very audible sound of the brakes when stopping. This is my first MINI, but I can't recall any of the disk-brake-equipped cars in my past sounding quite so loud - not squeal, just the sound of two surfaces rubbing together. If I heard this on an earlier vehicle I'd be out looking to see if I'd run out of brake pads.
Is it to be expected?
Old Jul 22, 2011 | 03:15 PM
ldye's Avatar
ldye
I've got 800 miles on my CS and hear the same noise. Have never experienced this with a Euro car. Ask my service mgr if Mini may have changed the pad compound and at first just blew it off. More we talked we said give it more miles and bring it in if it didn't clear up. I knew it wouldn't and what you're saying confirms it. He said they may have to replace the pads. I won't be able to get mine in for service for about 4 weeks. Please post if you find out anything.
Old Jul 22, 2011 | 03:21 PM
ldye's Avatar
ldye
Sorry about that double
Old Dec 22, 2011 | 06:51 PM
walk0080's Avatar
walk0080
Unfortunately the JCW brakes are noisy, especially in reverse.
After break-in, my JCW now makes a light sqeak for a short moment often when breaking while driving forwards. In reverse, it's a little embarrassing because they are LOUD. Loud enough that people will look as I am reversing.
Not sure if a mod can move this to the right sub-forum.
Gabe3
Tires, Wheels, & Brakes
16
Apr 16, 2016 07:55 AM
LordOfTheFlies
Oct 19, 2015 05:02 PM
theblackfalcon
Oct 11, 2015 09:49 AM
dscott90000
Aug 23, 2015 08:21 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
