Alta Intercooler Couplers R56
Old Sep 11, 2015 | 08:45 PM
5JCW6's Avatar
5JCW6
Hey guys I was wondering if anyone here knows where to find the couplers for the Alta FMIC(R56) as all the ones I find online say they're for R53s...not sure if they would be the same.
Would appreciate a quick response as I'm about to purchase the Intercooler itself, thanks!!
Old Sep 11, 2015 | 08:57 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
The R56 uses hoses not couplers. We would use the Forge hose or NM hose as the alta sets we've seen rub on the fan and get damaged easily.
And the Forge for the Turbo outlet cold side
http://www.waymotorworks.com/forge-s...rbo-hoses.html
We also have intercoolers for whichever you want.
http://www.waymotorworks.com/07-coop.../intercoolers/
But you can use the stock rubber hoses no problem with our res delete for a cost effective solution
http://www.waymotorworks.com/wmw-res...7-r58-r59.html
Old Sep 11, 2015 | 09:07 PM
5JCW6's Avatar
5JCW6
Awesome thank you,as for the hot side I believe I have an alta hose to delete the muffler already,would the only other thing i need is the forge hose for the cold side? Because im planning on purchasing a few things from your website such as the DdmWorks RIS and Cravenspeed short shifter so if this is the case i would just buy all 3 together.
Old Sep 11, 2015 | 09:25 PM
WayMotorWorks
Vendor
Yes the forge hoses only replace the rubber parts on the cold side as the main pipe is molded plastic to fit around the frame and engine.
W0TM8
Dec 19, 2019 07:50 AM
AWOL
Mar 28, 2016 10:51 AM
tr3y003
Oct 22, 2015 10:48 AM
stierzy34
Sep 15, 2015 04:40 PM
Lt. Dan
Aug 10, 2015 08:23 AM
