Buying JCW Intake
Old Nov 7, 2014 | 05:52 AM
  #26
Yep,
N18 airbox => N14 JCW Tuning airbox
You will have to buy the whole N14 box with the 4 screws: 13717577509
http://www.ecstuning.com/Search/SiteSearch/13717577509/
Then replace the top portion of the new N14 airbox with JCW Tuning kit top half.
John Cooper Works Tuning Kit Intake part # 13720429380
http://www.ecstuning.com/Search/SiteSearch/13720429380/
John Cooper Works Tuning Kit - Air Box With Tube Filter - Gasket Part # 13530433064
http://www.ecstuning.com/Search/SiteSearch/13530433064/
Also can go to the pipercross foam filter if you like.
Thats it.
Old Dec 31, 2014 | 10:59 PM
  #27
GEMSTER's Avatar
GEMSTER
So I bought the N14 airbox and the JCW top airbox, but I ran into fitment issues. The bottom part of the JCW airbox that sticks out (first pic) is hitting the silver thing in the second picture.
Is there anyway to fix it? I've taken off the part that sticks out for now, but the airbox is no longer sealed. :/
Old Dec 31, 2014 | 11:17 PM
  #28
Agbullet25's Avatar
Agbullet25
What engine is this on?
Old Jan 1, 2015 | 10:10 AM
  #29
GEMSTER's Avatar
GEMSTER
N18
Old Jan 1, 2015 | 10:28 AM
  #30
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Is there a reason why one would go through all that trouble purchasing both kit parts to make one Intake System ?
Will just Part no. 9 below for $135.00 suffice ?
Part no. 13712217674
Old Jan 1, 2015 | 10:37 AM
  #31
GEMSTER's Avatar
GEMSTER
It's because I wanted the JCW intake with the cone filter. And JCW cone filter was only for N14 engines. In order to fit to an N18, you needed to buy the N14 airbox to make it fit.
They do have a JCW intake for N18s, but it has a panel filter instead.
When you buy the JCW intake, it only consists of the top portion of the intake, as opposed to the whole airbox you see in the parts diagram.
Old Jan 7, 2015 | 02:48 PM
  #32
Yea, its the newest design on the fuel pump on the N18. it just comes out a bit more because of that line. But I did not think it would come that close, because I have seen it on other N18. First I have seen this tried on an N18 3/2012+ with an extended hose.
What year is your MINI. At worst I would notch that top lid bottom section and them seal it with tape or duct tape. Let me know if you can mod the upper box.
Old Jan 8, 2015 | 12:51 PM
  #33
-=gRaY rAvEn=-
Moderator
In some cases I have seen where a mod can be "over thought". I'd just get the hi flo panel filter from piper cross or similar. Spending 400 + then cutting it up may not be the best route.
Unless there are specific documented hp gains with the cone over flat air panel filter.
Old Jan 15, 2015 | 06:29 AM
  #34
R53's Avatar
R53
There's 3 different Intakes from the factory for the R56
The standard Cooper S one with a panel filter with a flat top.
The Stage 1 Jcw intake with a cone filter inside.
The Factory Jcw uses a similar intake to the Cooper S but the top half is completely different. It's more rounded and much bigger. It uses a panel filter inside.
I would assume the factory jcw one is the best one since the Gp uses the same system as well.
Old Jan 18, 2015 | 11:48 AM
  #35
GEMSTER's Avatar
GEMSTER
My GP was March 2013 production.
I was going to shave the plastic and duct tape it at first, but i was scared that the tape might melt.
I ended up removing the plastic part that stuck out and replaced it with a sheet of aluminium that i cut and drilled.
The airbox is mostly sealed now. There is only a small gap since my aluminium sheet just wasnt quite big enough. I will see if i can find a bigger piece of aluminium later and have it properly sealed.
Oh and thanks ECS Tuning for the speedy shipment of the intakes
Old Jan 19, 2015 | 11:23 AM
  #36
You are welcome, I am glad you got it to work.
Old Jan 25, 2015 | 04:21 PM
  #37
Zillon's Avatar
Zillon
Interesting, so this won't work on the GP without modification.
Panel filter it is, then.
Old Jan 25, 2015 | 06:17 PM
  #38
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I've got one for my GP as I really like the JCW intake since it showed good torque numbers. Taking off the little res box on it is no big deal so I wouldn't let that scare you.
http://www.waymotorworks.com/jcw-int...6-r55-r57.html
But if you do go with a panel filter go with the dry filter as it won't put any oil in the sensors.
http://www.waymotorworks.com/dry-pan...-cooper-s.html
Old Jan 25, 2015 | 09:48 PM
  #39
Zillon's Avatar
Zillon
I'd rather a plug-and-play setup - not into jury-rigging an intake. And $300+ to make it all work is a bit steep.
The aFe dry panel filter was at the top of my list, though - had one on my GTI.
Old Mar 21, 2015 | 11:17 PM
  #40
cguzz's Avatar
cguzz
gasket
I'm thinking upgrading to the JCW stage 1 intake as well. Couldn't I just cut out the rubber gasket from the paper filter that's in there and use it for the seal?
Old Mar 23, 2015 | 07:25 AM
  #41
Grizld700's Avatar
Grizld700
No the panel filter is not the gasket. There is a separate gasket along with the paper filter and its own built in gasket (which really isn't a gasket, but more of a place holder).
Old Mar 23, 2015 | 08:37 AM
  #42
Yep, separate gasket is up top and the filter is a tube version.
Old Apr 8, 2015 | 05:01 PM
  #43
cguzz's Avatar
cguzz
Maybe I didn't ask the question correctly but after my install it is a YES...
If you are upgrading to the JCW stage 1 intake, you take the old panel filter and cut out the rubber gasket around it (cut away the paper filter) and saved $28.18 + shipping.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
arf88
May 31, 2016 03:07 PM
nomar116
Aug 10, 2015 11:24 PM
xpunisherx
Aug 10, 2015 10:50 PM
