2009 Factory JCW Leaking Greenish Fluid
Old Oct 30, 2013 | 08:41 AM
SmokeM's Avatar
SmokeM
Hello folks. I got my JCW back from a state inspection and it seems that there is a light green fluid leaking from the engine. I've ruled out the brakes and coolant and it seems to be coming from the transmission but it's hard to tell exactly where it's leaking from. The trail comes from somewhere up top and snakes down alongside the transmission case (facing the rear).
It has never leaked until I took it in for an inspection. Do the tech's typically fill the transmission? Anyone else have this issue or have any leads?
Old Oct 30, 2013 | 09:07 AM
son-of-mini's Avatar
son-of-mini
green? sure sounds like coolant to me. I do not think transmission fliud is green, more likely yellow.
Old Oct 30, 2013 | 09:20 AM
Grizld700's Avatar
Grizld700
Could be dye from the A/C system. Most dyes are a bright green that is fluorescent under a "black light". Thats the only thing I can think of that could be green in your car.
Old Nov 15, 2013 | 09:28 PM
SmokeM's Avatar
SmokeM
Its coolant. It looks like its coming from a thing that a bunch of coolant tubes go into. Its black plastic . It sits on top of the transmission. That's why it was so hard to locate. It may be the thermostat but I'm not sure.
Edit: yup, here is the write up. Luckily it looks easy to do.
https://www.northamericanmotoring.co...hermostat.html
Old Nov 16, 2013 | 09:59 AM
jrs66's Avatar
jrs66
Originally Posted by SmokeM
Its coolant. It looks like its coming from a thing that a bunch of coolant tubes go into. Its black plastic . It sits on top of the transmission. That's why it was so hard to locate. It may be the thermostat but I'm not sure. Edit: yup, here is the write up. Luckily it looks easy to do. https://www.northamericanmotoring.co...hermostat.html
Be very carefull with the black plastic pipe that's goes to waterpump! that piece burnt me twice...
Old Nov 17, 2013 | 08:27 PM
SmokeM's Avatar
SmokeM
Burnt you twice as in, its easy to break? Thanks for this valuable tip!!!!
Old Dec 7, 2013 | 11:19 AM
Kylebeano's Avatar
Kylebeano
That sounds like the thermostat housing, I had to have mine replaced at 52k miles.
Sexual Chocolate
Mar 31, 2019 08:02 PM
marendt428
Nov 14, 2015 10:03 AM
Longjas
Aug 24, 2015 06:06 AM
ASRman
Aug 13, 2015 09:33 AM
