It would appear I suck at checking my oil...
Old Jan 22, 2012 | 09:39 PM
  #51
OceanMini2's Avatar
OceanMini2
Originally Posted by 312griso8v
I would tend to agree with you... although.. it will depend on how the oil is drained.
not sure if this has already been covered but, to get the most thorough drain it's best to drain the oil hot (at least 140F). first, drain the oil. second, change the oil filter (this will allow a small amount of used engine oil from the oil filter housing/lines to drain into the crankcase). third, drain the oil again. doing this will ensure the maximum amount of oil has been drained. fyi... it's a 1/2" drain plug.. not a 13mm...
oh, and I usually fill roughly 5 quarts per oil change. Maybe 4.8-4.9 qts.
and mine is an R53... not sure how R56 is set up.
I am thinking the best way to do an oil change on a R56 is to drain the oil hot then let the motor cool down to the point that the coolant hoses are no longer under pressure. Then when you move the overflow bottle to get to the oil filter the coolant hoses will flex some and not fracture. I would keep the drain plug out the entire time it takes to cool down and change the filter.
Old Jan 22, 2012 | 09:43 PM
  #52
OceanMini2's Avatar
OceanMini2
Originally Posted by d@g
...............As far as capacity goes, every reference I've seen (Bentley, BMW) says the N12, N14 engines have a capacity of 4.2L or 4.4 USQ. I don't know, though, if that is refill capacity or total capacity for a dry/new engine.
What BMW document did you find that listed in? I would like to have it. I need to get a Bentely for the Mini too.
Edit: I found the document.. 4.2L is what is listed for my Mini. Thanks!!
R50, R52 and R53
W10 (2006 MINI Cooper) – 4.50 liters / 4.7551 quarts
W11 (2006 MINI Cooper S)– 4.80 liters / 5.0721 quarts
R55, R56, R57 and R60
N12 (2007+ MINI Cooper) and N16 – 4.20 liters / 4.4381 quarts
N14 (2007+ MINI Cooper S) and N18 – 4.20 liters / 4.4381 quarts
Originally Posted by DneprDave
The Bentely Manual says it holds approximately 4.4 quarts, including oil filter.
Dave
Originally Posted by Minidrivr
Some one else has also mentioned looking down at the dipstick with it still vertical.
I agree, it's hard to read the dipstic. According to the owners manual, the space between the two metal marks is 1 quart, and the oil light in the dash will alert you if it is 1 quart low. So wouldn't that mean it will tell you if it hits the lower mark on the dipstick? Seems like you might not even need to read the dip stick if that is the case.
^^^This post about the oil light is just not true^^^
Originally Posted by 5zero4
Turns out I was 3 quarts low!!!!!
I checked the oil before a drive from L.A. to Sacremento only 3 weeks ago and it seemed fine. How the hell did I lose that much oil in 3 weeks? ...........I really wish there was a low level warning light or something when it gets at the most 2 quarts down. Even with 1 quart in there, there was never a low oil pressure warning light and the engine rattle was pretty loud.
....... Would an oil pressure gauge help to diagnose low oil before it gets too low?
I just hope it didn't do any damage.
The dealer told me the light comes on at 3 quarts low! Mini/BMW customer service told me it comes on at 1 quart low. OK what is the real story on this???
Old Jan 23, 2012 | 05:09 AM
  #53
IQRaceworks's Avatar
IQRaceworks
Originally Posted by STi2Mini
I have to add a quart of oil about every 1K miles. Get used to checking the oil on a regular basis. MINI says that its normal for the car to go through 1 quart every 750 miles. They said its normal for a "high performance turbo charged car." I think its a lame excuse as I had a 400hp Subaru STi that never burned a drop of oil.
Does anyone have any MINI documentation stating this? This sounds crazy...pretty hard to believe.
Old Jan 27, 2012 | 11:43 AM
  #54
Hawk 06MCS's Avatar
Hawk 06MCS
The night I picked up my car from the dealership I discovered that the factory stick was junk and had cracked about a third of the way down the stick. I immediately ordered the "Next Gen" replacement offered by Craven Speed. Kellen was very helpful and I encourage all Mini owners of the R53 crowd to check the stick in their cars and order this replacement if needed. The cut "rings" in the stick are very easy to read and don't leave you guessing.
Old Feb 9, 2012 | 07:42 AM
  #55
OceanMini2's Avatar
OceanMini2
Have you ever wondered how different the oil level reading is if your Mini is not parked on level ground? Most streets are sloped for water drainage. If you park your Mini on a typical street and check the oil level you could be tricking yourself.
First picture shows a clean stick.
Second picture shows an oil reading with a Mini parked on a 4 degree slope (US driver's side low).
Third picture shows the oil reading with the Mini parked on a level surface (in this case I used a jack and a bubble level).
If you check your oil with the passenger side on the low side of a slope you will see an oil level reading that looks much higher than the real oil level is (as long as you are not checking the oil on a RHD Mini). None of this may surprise you but note that more than half of the oil zone is dry in the test (or would be wet if the car was tilting to the other side).
The traditional location for the oil dipstick is in the center of the motor. The Mini S has a turbo located in the center and they found it necessary to move the dipstick to the "front" (looks like the passenger side) of the motor. This makes it necessary to check your oil on very level ground to avoid miss readings. Note how the traditional motor's dipstick (located in the center) has very consistent readings but the Mini R56 motor has a large swing when the motor is not level.
Old Jun 5, 2012 | 07:23 AM
  #56
Cactus Kid's Avatar
Cactus Kid
I don't own a MINI yet, but reading this kind of stuff makes me hesitate.
Are the base Coopers also chugging oil, or is this just a 'S' problem?
Old Jun 5, 2012 | 08:20 AM
  #57
DneprDave's Avatar
DneprDave
I have an "S" and it doesn't use any oil between changes, I check the oil weekly, though.
Car forums tend to have more people complaining about cars, giving the perception that there are widespread problems. No one comes to a car forum asking why their car runs well.
Dave
Old Jun 5, 2012 | 08:27 AM
  #58
OceanMini2's Avatar
OceanMini2
Not all Minis consume large containers of oil. I think that some of the owners ran low oil after thinking they did not have to think about oil for 15,000 miles (the factory supported maintenance schedule is very long). The Mini has no temp gauges and the design and marketing suppresses the fact that a Mini has a motor in it that requires some attention. I think the cartoon styling and the computer like user controls make people think that they are not driving a car at all.
Old Jun 7, 2012 | 10:37 AM
  #59
MINIMM's Avatar
MINIMM
Mine also doesn't use oil between changes at 7,500 miles.
Also check oil weekly.
Old Jun 7, 2012 | 11:02 AM
  #60
Tu13es's Avatar
Tu13es
So I had the cold start rattle about 3 months. I have already had the timing chain and tensioner replaced once, so when my engine was making the rattle again I thought that was what it was again.
Same thing happened to me in my 09 JCW. Granted I was probably 10K miles since last change. I'll be keeping a much closer eye on oil levels here on out..
Old Jun 7, 2012 | 11:35 AM
  #61
LittleWing's Avatar
LittleWing
My "S" engine does not burn oil and it is almost at 35K miles.
Not knowing any better, I have adhered to the recommended oil change schedule.
I just had my 3rd oil change.
Although I have been pretty consistent about checking my oil regularly, I now know that I probably didn't get accurate readings.
So, I plan to be more diligent about checking the oil and getting a good reading.
Also, I plan to step up the oil changes.
Looks like I need to keep a bubble level in the boot too.
At least I live in Florida and level ground is pretty much all we've got.
Thanks OceanMini2!
You clear directions and illustrations have been very helpful.
Old Jun 7, 2012 | 12:07 PM
  #62
MCS Fever's Avatar
MCS Fever
Our S used 1/2qrt in the first 5,000 miles - I have the dealership service receipt showing they topped it off at my request when it was in to fix the bubbling chrome hood scoop. Have not needed any since, in fact it is a little over full ever since the last service a couple thousand miles ago.
Old Jun 25, 2012 | 09:17 AM
  #63
sonofray's Avatar
sonofray
New (to me) 2007 MC non-Sport, 88k miles. YES they do consume oil too.
Only had it for a couple months (put 2-3k on it). Last week noticed erratic behavior in stalling at lights, and over a couple days the check engine light came on once (and left), oil symbol came on once (then left), service light came on once (then left), then oil again (and left). Called dealer to schedule appt. Was worried about stalling out somewhere until appointment, so dealer recommended checking oil and putting in a quart. Couldn't read %$#& on the dipstick but put in a quart. Later dealer put in another 2ish quarts (total of 3ish)
Still not sure how I'm going to check it. Now I'm off search for "best type of retail oil to use." (M1 deal at Costco!).
Old Jun 25, 2012 | 11:49 PM
  #64
OceanMini2's Avatar
OceanMini2
For starters I would just use the Mini / BMW oil at the dealer.
Please take the time to learn how to check the oil level.
https://www.northamericanmotoring.co...81-post39.html
https://www.northamericanmotoring.co...41-post79.html
https://www.northamericanmotoring.co...54-post80.html
https://www.northamericanmotoring.co...4-post100.html
https://www.northamericanmotoring.co...5-post109.html
Old Jun 26, 2012 | 08:50 AM
  #65
sonofray's Avatar
sonofray
Thanks! I've read a number of those and will continue to refine my technique (and potentially get the Craven Speed dipstick). Would've been nice to be tipped-off at my dealer of the need for frequent checking, but I know now!
I'm going to try and pick up some MINI oil, but when the dealer service tech told me to put in a quart I wasn't prepared and had to go retail (didn't know how low it was, or if I'd be stranded soon).
Thanks for the links and advice!
Old Aug 3, 2012 | 03:58 PM
  #66
markr's Avatar
markr
As did my '09 after approx. 8k since last change.
Old Aug 16, 2012 | 06:28 AM
  #67
teamrodney's Avatar
teamrodney
I've a European spec JCW in Australia which uses no oil but I change it every six months but I am going to invest in the Craven Speed dipstick at $75 it seems good insurance.
Old Jun 30, 2014 | 09:59 AM
  #68
minMINI's Avatar
minMINI
My R56 MCS 2009 is in for its second engine replacement! In Norway we have an expression: "Monday car"... based on the thougt that some cars are assembled on a monday after a rough weekend..I think I've might got a mondays car.. The dealer has been very helpful and documented everything so that the engine change will be changed free of charge! This time the (also free) rental car is a BMW 320i Sport. Nice car, but Mini is what I like!
Casrio
Apr 20, 2021 01:52 AM
CardinalsRule
Jun 11, 2016 04:34 PM
mimaal
Sep 4, 2015 09:09 AM
M7Speed
R58 :: Coupé Talk (2012+)
Sep 3, 2015 07:29 AM
M7Speed
Sep 3, 2015 07:27 AM
