Aftermarket wheels that fit R56 JCW brakes
Subscribe
Nov 18, 2010 | 11:00 AM
  #126
I haven't noticed any squeal specifically when backing up.
I do get the "normal" brake squeal from time to time, during light application of the pedal; stops when I push a little harder, of course. It seldom gets to the point of being annoying.
Reply 0
Nov 18, 2010 | 11:04 AM
  #127
Mine squeal a bit more than I'd like, and like you say here, especially when backing up and gently applying the brakes. Granted, I only have 600 miles on him, so it may not last for ever, too.
Reply 0
Nov 18, 2010 | 11:09 AM
  #128
Quote: Any squeal from yours? Or, did it disappear after awhile? Thanks.
Yes, only when backing up. And no.
Reply 0
Nov 18, 2010 | 11:42 AM
  #129
Mine squeal backwards and forwards, but only when I park outside overnight. If I park in the garage, there is 0 squeal the next day. Weird.
Reply 0
Nov 18, 2010 | 11:53 AM
  #130
Mine squeal but only when going forward and not all the time and only the driver side front. It happens more when the car is "hot", driving long distances.
I suspect It needs to be loaded up with alot of anti squeal compound. The dealer can't fix it because they can't reproduce it. Once it comes out of warranty I'll get to the bottom of it, if I can, and fix it. I've read people say the Brembos squeak so I'm not too worried about it.
Reply 0
Nov 18, 2010 | 09:16 PM
  #131
Another thought that I had about the squeal too, is that the weather is starting to get cold. It didn't get over 35 degrees today, so that gives you an idea. That, and the brakes still may have to seat themselves too.
Reply 0
Nov 20, 2010 | 02:02 PM
  #132
Here is my JCW with Motegi SP-10. I bought these for snow tires and like them more than I thought I would. The silver stripe inside goes pretty well with the chrome trim.
More pictures here.
http://www.flickr.com/photos/3661564...7625307739327/
Reply 0
Nov 21, 2010 | 03:51 PM
  #133
Say, I thought that the JCW brake rotors were cross drilled. Where are all the plain rotors coming from? Stock?
Reply 0
Nov 21, 2010 | 09:10 PM
  #134
JCW cross drilled rotors?
Quote: Say, I thought that the JCW brake rotors were cross drilled. Where are all the plain rotors coming from? Stock?
The cross drilled JCW Brembo Brakes are the $2000. package. To have cross drilled on a JCW it is a $300 dealer installed option. Don't know if that would help with the brake squealing though. Most have said that the cross drilled rotors is more cosmetic than effecitive.
Reply 0
Nov 22, 2010 | 04:00 PM
  #135
Quote: The cross drilled JCW Brembo Brakes are the $2000. package. To have cross drilled on a JCW it is a $300 dealer installed option. Don't know if that would help with the brake squealing though. Most have said that the cross drilled rotors is more cosmetic than effecitive.
Thanks - This helps, but not looking to stop squealing - looking as a possible track upgrade The cross-drilled are generally not a good idea on the track because the rotors tend to crack around the holes. I also had the holes plug up with brake dust which then cause the brakes to chatter. So it is plain rotors for me.
With that said I know people who are running the JCW/Brembo crossdrilled rotors on the track with no problem - go figure
Reply 0
Nov 22, 2010 | 05:06 PM
  #136
I've always used slotted rotors on the track and ummmm... spirited... street driving, and they've always served me well.
Reply 0
Feb 6, 2011 | 02:28 PM
  #137
Here are my winter tires on new black rims. Ok but not lov'in them.
Reply 0
Feb 28, 2011 | 06:36 AM
  #138
Quote: You should throw a pic of the mounted NTO3+Ms up so we can see.
Sorry it took so long...one of my run-flats is shot so I swapped on my autox set.
Reply 0
Feb 28, 2011 | 07:37 AM
  #139
And as is so common, there is a MINI *and* a Miata in the driveway.
Reply 0
Apr 7, 2011 | 04:15 AM
  #140
Dan: I know that it is here somewhere, but what are the recommended tire sizes for the Rota RB 17" wheel for my JCW? Right now I have 215 x 45 x17" but I thought that maybe a 40 size might work, but have no idea what height. I've heard about 235 x 40 x 17, but Tire Rack doesn't seem to have a good selection of that size in well recommended tires.
Reply 0
Apr 7, 2011 | 05:48 PM
  #141
Quote: Sorry it took so long...one of my run-flats is shot so I swapped on my autox set.
Hmmm. Thoughts these powder coated white on my JCW.. ?
Reply 0
May 23, 2011 | 08:12 AM
  #142
Any further updates? I'm in the market for new wheels and would love to see some more styles.
Reply 0
Jun 6, 2011 | 11:35 PM
  #143
NM Engineering RSe07 18" rims
Quote: Any further updates? I'm in the market for new wheels and would love to see some more styles.
I have the NM Engineering RSe07 18" rims...
http://www.nm-eng.com/nm880701s-nm-e...ght-wheel.html
These clear the JCW brakes no problem and replaced a set of JCW R105s (18") that wouldn't without spacers.
Reply 0
Jul 11, 2011 | 08:32 PM
  #144
just found out that I didn't catch that, a valet from yesterday put a huge curb rash on my jcw challange rim
looks like i might be getting new rims sooner rather then later.
BMC_Kid those NM wheels are hot and so is your mini!
Reply 0
Jul 12, 2011 | 03:35 AM
  #145
Sorry for being off topic, did you have to trim the Rocky Mounts to clear the hatch? That's the euro version?
Reply 0
Jul 12, 2011 | 07:37 AM
  #146
Love the wheels BMC. I was looking at those as well but ended up picking up a set of used R105s like you had for a price I couldn't turn down (using a 5mm spacer).
Reply 0
Jul 12, 2011 | 07:48 AM
  #147
Quote: Sorry for being off topic, did you have to trim the Rocky Mounts to clear the hatch? That's the euro version?
Yeah, they are the euro mounts and they were trimmed. The guys at RM installed them for free and did the trimming. With the hatch up, there is about a 1" space between the end of the tray and the hatch.
Reply 0
Aug 13, 2011 | 09:01 PM
  #148
Sorry if this has already been answered, but does anyone know if OZ Alleggerita's will fit over the JCW brakes?
Reply 0
Aug 13, 2011 | 09:41 PM
  #149
OZ Alleggeritas in 17X7 with 37 offset clear much more than OEM and are much lighter and the offset moves the tire out just right even with my 2009 factory JCW lower 2" from stock on coilovers. I had 205-45-17's and no rub.
Reply 0
Aug 13, 2011 | 10:32 PM
  #150
Thank you!!
Reply 0
