Aftermarket wheels that fit R56 JCW brakes
#151
looking skinny snows for 09 JCW
Any wheels that are 6-6 1/2" wide with skinny snows that would fit over the JCW brakes on a 09?
#153
If they're not on here already, add Focal F05 on the list
I just got these for my JCW as winter wheels, they're 17"x7.5" offset 42 (I believe, may be 38 not 100% I forget.) They have a plastic hub adapter, and there's no vibration with them, perfectly smooth. What's great about these wheels is there is TONS of caliper clearance (comparing to the mesh JCW wheels) they're also super cheap, $118 a piece. I weighed them with Blizzak LM60 tires and they EXACTLY the same as the 17x7 JCW wheels with Dunlop tires. Both are 43.75 lbs with tires, and I actually really like the way they look on the car, maybe even more so than the stock wheels! They also make the car look lower because the tires are so chunky. Will post pics tomorrow if anyone is interested.
#154
#155
Aftermarket Wheels
Hi Tata;
You want and need a wheel with a 42 offset. I wouldn't waste your time with 17" wheels. Replacing 17" with 17" is like kissing your sister!
Keep your factory wheels and tires intact and go for 225-40-18 or 225-35-19 on 7.5" rims you will never have a rubbing problem. The 225-40-18 (wrapped in Nitto 555 rubber) is the size I have and it totally corrects the 6 MPH speedo error at 80MPH and handles like it is on rails!!
I regularly put 500 lbs in the back and the tire disappears into the wheel well but never scrapes!
Looks good and works better!
Good Luck!
Good Luck!
#158
Has anyone tried these replica wheeels?
http://www.ebay.com/itm/17-SILVER-MI...item1e69ef5059
They look good and in my e-mail contact with them they say they will fit the JCW brakes.
#159
#161
I believe the brakes on R53 JCW are what the R56S have now, hence they can runner smaller wheels
#164
Yes, the 09+ Factory JCW only comes w/the big brake kit. Just pointing that out to make sure no other readers / less technical owners come along, read that, and think maybe their 09+ Factory JCW has a smaller brake kit and they can accommodate 16" rims.
#165
Thanks. I liked the R105s but they were so damn heavy. These new NM Engineering rims are very light and so much easier to keep clean. I gave the new owner of the old rims a great deal too!
#168
#173
--Dan
Mach V
#175
