F60 :: Countryman Talk (2016-2023) F60 Countryman discussion
F60 Piano black illuminated - photos or videos?
Old 12-31-2018, 09:24 PM
sch's Avatar
sch
sch is offline
Do any of you have photos or videos you can share of what the “piano black illuminated” interior actually looks like? The picture in the confugurator isn’t that helpful.
Old 01-01-2019, 02:02 PM
Camer0nes's Avatar
Camer0nes
Camer0nes is offline
The following 2 users liked this post by Camer0nes:
Frogain (01-02-2019), sch (01-01-2019)
Old 01-14-2019, 12:51 PM
BTDUBS's Avatar
BTDUBS
BTDUBS is offline
Is there any way to retrofit this to an F60 without it? It was 1 of 2 things that mine didn't come with that I wanted.
Old 01-19-2019, 08:53 AM
Madman23's Avatar
Madman23
Madman23 is offline
Wow!! That is such a nice touch.
Old 01-22-2019, 05:59 AM
MNCNTRYMN's Avatar
MNCNTRYMN
MNCNTRYMN is offline
My thought exactly... I'm sure there is a way, but curious about the level of effort.
Old 01-25-2019, 12:31 AM
pw1114's Avatar
pw1114
pw1114 is offline
It's most likely possible. I retrofitted the illuminated door trim on my F54 Clubman myself. The car would need to have ambient lighting package though; most countrymen, if not all of them, should have ambient lighting. The trim is just held in by clips, so should not be too difficult.
Old 01-25-2019, 06:47 AM
ND40oz's Avatar
ND40oz
ND40oz is offline
I wonder if the electrical connectors are there for the dash trim though. Did the door trim have a separate connector or did it use one that the old door trim already had or was it just light tubes and used the existing ambient lighting for it?
Old 01-25-2019, 12:09 PM
pw1114's Avatar
pw1114
pw1114 is offline
The doors have a wiring harness with connectors for the lighting (map pockets/door handles/illuminated trim). So the trim does require a connector. If the electrical connector is not behind the dashboard (very likely), you can just splice wires into any of the ambient lighting.
I also added illuminated color changing ambient lighting into the rear door map pockets simply by splicing into the wires. I added the illuminated trim using the proper wiring harness and connector.
ND40oz (01-26-2019)
Old 01-25-2019, 12:33 PM
BTDUBS's Avatar
BTDUBS
BTDUBS is offline
This is all very interesting. I think the price of the part may be the worst part, but my Mini dealer can't seem to figure out pricing on it.
Old 01-25-2019, 01:34 PM
Budgett's Avatar
Budgett
Budgett is offline
a few days ago dismount the central ring with the screen, and there were some connectors without connecting just in the area that lights up if you take the pack excitemen, it is possible that changing the panel that carries the lighting and coding worked
ND40oz (01-26-2019)
Old 01-25-2019, 03:43 PM
pw1114's Avatar
pw1114
pw1114 is offline
The best thing to do is try to find one from eBay from a wrecked car. I got, for my clubman, the door panels with illuminated trim and wiring from eBay for a little over a hundred bucks. It might be prohibitively expensive for new parts, or it might not. Parts pricing seems really random at times.
if the car already has ambient lighting, no coding would be needed, you just have to wire/connect it. All ambient lighting is centrally connected.
ND40oz (01-26-2019)
Old 01-26-2019, 03:59 AM
ND40oz's Avatar
ND40oz
ND40oz is offline
I may buy the drivers side since it's not that much money to see if I can get it to work, if so, then I can just buy the passenger side. Here's what I'm seeing for part numbers and pricing:
Decorat.trim driver's side illuminated (Left hand drive) PIANO BLACK 51459350473 €48.07
​​​​​​Dec. trim passenger's side illuminated (Left hand drive) PIANO BLACK 51459350474 €201.94
Old 01-26-2019, 04:31 AM
pw1114's Avatar
pw1114
pw1114 is offline
The driver side is not actually illuminated though; it's just labelled as illuminated because of the pattern printed on it to match. Only the passenger side lights up.
I was looking at pictures of the back of the trim online and it looks like it requires several LED modules, part no.: 63319263454
Coincidentally, I bought these same modules to create ambient lighting for my rear door map pockets.
These modules (3 are needed I believe) click into the trim and are what need to be connected by wiring.
You can see the back here on this RHD gold version:
https://www.ebay.co.uk/itm/Genuine-M...-/323427384628
lights connect to trim like this:
Old 01-26-2019, 07:03 AM
ND40oz's Avatar
ND40oz
ND40oz is offline
Crazy that they charge an extra €17 for that pattern over the normal piano black.
Yeah, we're almost guaranteed not to have those connectors behind the current trim, I wonder if there is the spare wiring or we'll have to tap the existing ambient lighting.
Old 01-26-2019, 01:22 PM
BTDUBS's Avatar
BTDUBS
BTDUBS is offline
Yeah, I am totally in. Price isn’t bad, I just really want to make sure it will work.
Old 01-26-2019, 01:31 PM
Budgett's Avatar
Budgett
Budgett is offline
but if it is not encoded, how are you going to change the color of the lighting of the LEDs? or your idea is that there is only one color?
Old 01-26-2019, 01:53 PM
ND40oz's Avatar
ND40oz
ND40oz is offline
It's already coded for ambient lighting, you can change between the colors.
Old 01-26-2019, 02:46 PM
Budgett's Avatar
Budgett
Budgett is offline
But my car has white lights in the area of the feet, that's the ambient lights?
Old 01-26-2019, 04:54 PM
pw1114's Avatar
pw1114
pw1114 is offline
If your car has ambient lighting, your footwell lighting should have available base colors of red, blue, and green(or is it yellow?); these are the basis of the various colors you can achieve. You would also have a toggle switch in the overhead panel that controls the colors. If you don't have these things, you don't have ambient lighting, and it would probably be prohibitively expensive even if you found a way to retrofit the dashboard panel since you would need a new overhead console toggle switch set as well.
If you do have ambient lighting, just splice the wiring into the footwell lighting if the car is not already pre-wired for the dashboard panel.
I suppose you can wire it to only have one color permanently if you don't have ambient lighting?
Old 01-27-2019, 06:23 AM
Budgett's Avatar
Budgett
Budgett is offline
my car has two LEDs on the roof, two lines on the front doors and another led in the area under the air conditioner, all orange, also has lighting in the area of the feet with white light, I have no switch to change the color on the roof.
Old 01-27-2019, 11:56 AM
ND40oz's Avatar
ND40oz
ND40oz is offline
Do you have 4V9 the Mini Excitement Package? I think ambient lighting is standard now but the Excitement pack is what adds the colors.
Old 03-25-2019, 06:14 AM
mattyb13's Avatar
mattyb13
mattyb13 is offline
About to pull the trigger on my 2019 Custom Iconic F60 build with my local mini dealer. I have chosen to go with the Illuminated Piano Black interior but I am nervous that it is distracting or takes away from the classiness fo the Chesterfield Oak interior? Any feedback from those of you that already have the Illuminated Piano Black interior would be super helpful. Is it too much? Distracting while driving at night?
Thank you!!!
Old 04-05-2019, 09:06 AM
BTDUBS's Avatar
BTDUBS
BTDUBS is offline
How much wiring is needed? Is it plug and play? If so I will go down to the dealer and order the part.
Old 04-21-2019, 01:54 PM
gareth12468's Avatar
gareth12468
gareth12468 is offline
Thank you!!!
No distraction at all.
Old 02-16-2020, 02:23 PM
varma1986's Avatar
varma1986
varma1986 is offline
What is the part number for Right Hand Drive?.
Quick Reply: F60 Piano black illuminated - photos or videos?
