F60 :: Countryman Talk (2016-2023) F60 Countryman discussion
F60 Q: Paddle Shift on Countryman S E F60?
Old 06-29-2019, 10:56 AM
ApexF60SE's Avatar
ApexF60SE
ApexF60SE is offline
All,
Was paddle shift an available option on the 2018 F60 Countryman SE? Or, has anyone retrofitted these to one successfully?
RealOEM doesn't show this as a variation for the SE model. Wiring diagrams do show it in the F60 SE diagrams. https://www.newtis.info/tisv2/a/en/f...sor/1VnXnbbTNo
TIA.
Old 06-29-2019, 11:54 PM
ND40oz's Avatar
ND40oz
ND40oz is offline
Have you checked the coding options to see if you can code the sport automatic transmission for the SE? IIRC, that was a requirement for the paddle shifters.
ApexF60SE (06-30-2019)
Old 06-30-2019, 10:14 AM
ApexF60SE's Avatar
ApexF60SE
Thanks for the reply...
I have not yet, but the VIN lookup states the trans is: STEPTRONIC Automatic, 3.944 Axle Ratio.
The floor mounted shift has a M/S position to the left of D.
Sport or not?
TIA
Old 07-01-2019, 07:26 AM
ND40oz's Avatar
ND40oz
ND40oz is offline
The SE does not have the Sport Automatic from the factory. It usually can be coded for vehicles that have the option. The reason I ask if you have the option to code it in for your car is pretty much every vehicle that has paddle shifters has the Sport Automatic option. If the SE doesn't even have the option for it, then I doubt the paddle shifters would work since you wouldn't be able to code the car for them to work.
ApexF60SE (07-02-2019)
Old 07-02-2019, 08:37 PM
ApexF60SE's Avatar
ApexF60SE
You called it...
I spoke with a dealer and gave them my VIN, asking if it had, or there is an option for, a sport trans. They looked it up and my SE does not have sport, nor could they find that it was an option when compared to the CM S.
So, no paddle shift for me!
Old 05-19-2021, 01:34 PM
varma1986's Avatar
varma1986
varma1986 is offline
I want to Retrofit the Paddle shifters on my 1.5lt 2018 Automatic Transmission CountryMan F60.
What does i need to do to make it happen?.
Can i change my steering wheel to the one with the paddle shifters & do a coding to make it work?.
Do I need to make any other modifications/cabling additionally?.
ChrisMCS04
01-18-2009 07:46 AM
ChrisMCS04
04-04-2008 09:06 PM
sambusik
03-07-2004 04:40 PM
MINIGreatness
02-13-2003 07:45 PM
Quick Reply: F60 Q: Paddle Shift on Countryman S E F60?
