F60 :: Countryman Talk (2016-2023) F60 Countryman discussion
F60 Anybody elses wipers stutterlike noise?
Old 01-03-2018, 12:30 PM
Miniminic's Avatar
Miniminic
Miniminic is offline
On my F56 the wipers had a squeeky noise which went away after spraying WD40 on the screws of the wipers. On my F60 i tought they would have fixed wiper issues, but on these my wipers have a strage screaming noise like they are stuttering as if the window isn't wet enough, like it is dry. Anyone else have this?
Old 01-03-2018, 12:46 PM
H_C's Avatar
H_C
H_C is offline
What are the condition of your wipers? The rubber portion may be fine but the mechanism holding it together may be deteriorating.
Don't spray WD-40 on anywhere near your window. It's just water and oil. It'll leave your glass blurry and hard to see at night. Also, it'll promote rust on your screws.
Old 01-03-2018, 01:12 PM
Miniminic's Avatar
Miniminic
It's a 6 months old CM. A demo car. Can't be deteriorating right? Looks like new. Didn't know wd40 had water in it...I didn't put it on this car
Old 01-03-2018, 01:22 PM
H_C's Avatar
H_C
H_C is offline
Hmmm. Maybe you can switch the wipers to source the odd noise.
My point is that WD-40 is not a good lubricant.
Can you post a video?
Old 01-03-2018, 01:29 PM
Miniminic's Avatar
Miniminic
You Tube
"> You Tube
" type="application/x-shockwave-flash" width="425" height="350">
Old 01-04-2018, 07:07 AM
TheOriginalKonky's Avatar
TheOriginalKonky
TheOriginalKonky is offline
Mine don't do that, but I will say the blades are garbage. Mine steak and don't do a clean wipe at all. (Car is brand new)
Old 01-04-2018, 08:07 AM
S-2013's Avatar
S-2013
S-2013 is offline
You might need to tweak the wiper arm by twisting it slightly towards the direction of the skip. I often do this after replacing wiper blades. I do this to make sure rubber edge is perfectly perpendicular to the glass.
Old 01-04-2018, 12:54 PM
Miniminic's Avatar
Miniminic
Hmm is there a tutorial or video showing how to do this before i do it wrong 🤭
Old 01-04-2018, 02:16 PM
S-2013's Avatar
S-2013
S-2013 is offline
View this video to get a better idea of what needs adjusting. I usually use an adjustable wrench with a rag over the arm to protect the finish. Tighten the wrench on the arm up close to where it pivots with the blade and gently twist towards the direction it’s skipping or chattering. Usually will take several tries to get smooth operatiing wipers.
Old 01-05-2018, 07:43 PM
MrFunk's Avatar
MrFunk
MrFunk is offline
I've noticed that if you've treated your window with a sealant that can happen.
Old 01-05-2018, 07:56 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Minnie.the.Moocher is offline
Why not have the dealer fix it?
Old 01-08-2018, 09:36 AM
Seabiscuit's Avatar
Seabiscuit
Seabiscuit is offline
quote:
Mine does that if there is not enough moisture on the windshield. I view that sound as a 'sign' to turn off the dam wipers.
Yeah have the dealer put a new set of blades on there and be done with it. Or run by chiner-mart and pick up a set of Michelin stealth blades, they are quiet,
Old 01-10-2018, 10:54 AM
Miniminic's Avatar
Miniminic
So went to the dealer for some startup issues. Thankfully, they changed the wipers. Haven't had decent rain since, but for now they are silent )
ThEgMaNofCourse
01-15-2012 11:11 PM
SniperDetailing
12-10-2011 10:39 AM
idoc
36
02-07-2007 10:36 AM
02s79fj40
01-30-2004 12:03 AM
Quick Reply: F60 Anybody elses wipers stutterlike noise?
