F55/F56 Transmission Mount Hassle.
Old Jan 4, 2024 | 08:50 AM
slowsvt's Avatar
slowsvt
Decided to come on here & see if I can out a few of you since I wasn’t able to find any clear help. But yes the average DIYer can do this job in their garage. The removal of the battery tray, battery & computer is needed to create room to work, on the bottom you have just have to loosen the subframe bolts a bit, loosen the control arm bracket bolts & remove one end of the sway bar link to create enough room to remove the transmission mount. Removal of the driver side fender liner & wheel obviously helped. You may need to pry the transmission down a bit to creat that little extra room but just know it can be done as I’m just finishing up the mounts on this JCW.
Old Jan 4, 2024 | 11:59 AM
Thanks for the info, this is one of the only post on here about it.
https://www.northamericanmotoring.co...mount-diy.html
Old Jan 4, 2024 | 02:47 PM
slowsvt's Avatar
slowsvt
Yeah I was looking a few hours online for some help & didn’t find anything useful so figured i’d make a post maybe help someone out.
woodstudio
How to
17
Oct 27, 2014 12:58 PM
mini22
Apr 6, 2014 01:34 PM
micromini234
Jan 1, 2012 05:30 PM
NC TRACKRAT
Aug 4, 2008 06:53 PM
cpayne
14
Jul 25, 2007 10:22 AM
