F55/F56 Ramps
Old May 6, 2023 | 04:29 PM
TVPostSound's Avatar
TVPostSound
Ramps
Anyone using ramps.
While being 1" lowered
With a splitter!!!
And what's with the 3 different brands I see using the name Rhino Ramps??
Old May 7, 2023 | 04:04 PM
MikeMJCW's Avatar
MikeMJCW
I have Rhino ramps 11909. My F56 is lowered probably over 1cm by now. The factory front splitter does make contact with the ramp, I built an extension with some wood and run a lag bolt thru to fasten them together.
See my old post
https://www.northamericanmotoring.co...2339046-a.html
Old May 9, 2023 | 11:01 AM
TVPostSound
Mine is lowered 1 inch (2.5 cm) with a Schnitzer splitter.
I just ordered a set of 11909 from Amazon, can always return them!
Old Jan 14, 2025 | 01:15 PM
Usheenayer's Avatar
Usheenayer
I’ve used ramps before, and if you’re lowered by 1 inch with a splitter, you want to pick something that’ll give you enough clearance without scraping. I’ve found that some ramps can be a bit too steep, especially with a splitter, so I’d suggest looking for a set with a more gradual incline. As for the whole "Rhino Ramps" thing, it’s a bit strange. A few different brands are using that name, but they all seem to do the job well enough. If you’re in New Zealand, you might want to check out car ramps nz for a solid range that could work for your setup.
Old Jan 17, 2025 | 04:56 AM
Stu-mon's Avatar
Stu-mon
I got a 3" drop & I'm still lookin' if I wanna even bother. Just go to Mini not too often , I gotta have a reason to get under there. Ima old man
Old Jan 23, 2025 | 01:49 PM
johnnys2quick's Avatar
johnnys2quick
race ramps has options, I use them and they work on both the lowered Mini and the lowed Mustang
Improstrat
Oct 8, 2013 05:29 PM
Supertuner12010
Jan 3, 2011 05:31 PM
uscfan
Mar 5, 2007 06:21 AM
JuniorMint
Sep 25, 2006 07:13 PM
ugly_duckling
Aug 31, 2005 10:37 AM
