F55/F56 Maintenance Question
Old Jul 13, 2022 | 04:35 AM
BobHMini's Avatar
BobHMini
Good Morning,
I have a 2015 F56 automatic and currently I have the oil changed and tires rotated every 5K miles. I have the air filter and micro cabin filter changed every 10K miles. I have the brake fluid changed every 30K miles and the spark plugs changed at 60K miles.
My question is how often should the following items be changed and are there any items that I am missing:
Automatic transmission fluid
Radiator flush
Thank you,
Bob
Old Jul 13, 2022 | 07:45 AM
ICEE's Avatar
ICEE
probably check the motor mounts. The top mount tends to let loose.
Old Jul 13, 2022 | 09:21 AM
TVPostSound's Avatar
TVPostSound
Originally Posted by BobHMini
Good Morning,
Radiator flush
Thank you,
Bob
MINI says the ATF is lifetime, HA!!
60K drain and fill, its 3 liters.
Coolant? From my observation with BMWs, also Toyota, coolant seems to hold up way past 100K.
Gone are the days of cast iron block, in which rust was your enemy.
But I would do a drain and refill at 60K, just use the coolant recommended by MIN, it has the correct additives for that engine.
Old Jul 14, 2022 | 05:34 AM
NBCGLX's Avatar
NBCGLX
You should also be consulting the built-in CBS. For example, my F57 specified that the spark plugs be changed around 30,000 miles.
Old Jul 16, 2022 | 07:36 AM
Tio Barry's Avatar
Tio Barry
If the computer says to change plugs at 30k then MINI pays(?)
Old Jul 16, 2022 | 08:30 AM
NBCGLX's Avatar
NBCGLX
Not for me, I was beyond the 36 months of free maintenance. If you hit a maintenance item like that within the free maintenance period, not sure if MINI would pay (because I’m not sure if MINI covers spark plugs). I changed them myself in about 15 minutes in total.
Old Jul 16, 2022 | 10:33 AM
TVPostSound
Used to be everything under 36K with the 2 Gen. My R56 got brakes, wipers, and plugs. No more.
Steve_LV
Apr 5, 2016 06:37 PM
elightbo
19
Oct 29, 2015 10:39 AM
Minicoopr50
Apr 18, 2012 02:56 PM
Powashiftin
Sep 14, 2011 08:44 PM
MrTIer
Aug 6, 2008 05:51 PM
