R58 A/C Blend Door Actuator challenge 2014 Mini Cooper 2 door
Old Feb 24, 2022 | 12:00 PM
pgersbsf's Avatar
pgersbsf
Hi all
I noticed the AC was only blowing cold air on the passenger's side in my Mini Cooper 2014. I did some research and it seemed it was the blend door actuator.
I removed the existing actuator, and moved the blend door manually, and it does work as expected...hot when I turn it one way, cold when I turn it the other way.
So I ordered a new actuator, but when I plug it in, it does not rotate (the old one rotated, no problem). I thought it was a bad part so I got another one. Same issue. The actuator part does not move regardless if I adjust the temperature high or low.
I cannot figure out what to try next. Does the actuator need to be reset or calibrated for it to start responding?
Thank you
Old Sep 28, 2022 | 06:09 PM
Minimaniac69's Avatar
Minimaniac69
That’s a great question … I too need to know the answer to this as I’m having the same issue.
Old Oct 7, 2022 | 05:06 AM
Stu-mon's Avatar
Stu-mon
I don't have problem side-to-side but when I start-up my flow goes down & dash at same time THEN goes to dash full time. it's a vacuum thing, think about that ?
OldElvis
Mar 26, 2019 07:00 AM
clumanjenn
Jul 14, 2010 05:12 PM
markp
Apr 5, 2009 09:36 AM
