F55/F56 P0440
Old Aug 2, 2020 | 07:45 AM
TkPk's Avatar
TkPk
P0440
Hello. I have a 2016 F55 (S), picked up CPO after my 2014 F55 self immolated. :-(
A few days after the CPO warranty expired, it threw a P0440. I performed a simple inspection of the gas cap and cleaned the ring and seat. I've done some searching and not finding much online about diagnosing the P0440.
Would someone please point me to some guidance on resolving this?
Thank you
Old Aug 2, 2020 | 08:16 AM
Arrivederci Zagato's Avatar
Arrivederci Zagato
I've had this one before.
It may be the gas cap and if it is then tighten it and it should go away in a few cycles.
If not, then likely it's the fuel tank breather valve, part no. 13907621174. Very easy DIY replacement and you could probably find the discounted OEM part somewhere on eBay like I did if you don't want to shell out $110.
DIY involves just pulling a clip and it is located right in front of the engine.
Let me know if you have any questions!
Old Aug 2, 2020 | 08:29 AM
TkPk's Avatar
TkPk
Thank you
Thank you. This has been going on for a bit, after both a fill up or two, opening and closing the cap, etc. The code went away for a couple days and then came back, so I'll look at replacing the valve. Thanks!
Old Aug 13, 2020 | 03:01 PM
TkPk's Avatar
TkPk
Do you remember if the fault cleared up instantly after installation or if it takes a few cycles? As you can imagine, I installed the new valve, turned on the car and took it around the block and the fault was still there. But that's only one cycle.
Old Aug 13, 2020 | 03:05 PM
Arrivederci Zagato
If I recall correctly, it took a few cycles before it went away, but it did not stay for more than a day. I recommend seeing if it goes away after going through a full tank of gas before looking into it further. Does the car seem any different with the code on?
Old Aug 17, 2020 | 07:34 PM
TkPk's Avatar
TkPk
Thank you. Fault is gone. I'm hopeful it stays that way! No, car didn't seem different at all, fault or not.
Old Aug 17, 2020 | 09:16 PM
Arrivederci Zagato
Great, that's what I love to hear! Generally, those valves go bad after topping off at the pump regularly. I'm glad it seemed to have fixed the issue for you, knock on wood.
DDodge
Feb 8, 2018 09:53 AM
dm33
May 7, 2016 06:09 PM
Martys
Apr 21, 2016 04:05 PM
Misc
Oct 23, 2015 04:43 AM
