F55/F56 F56 Lower engined mount
Old May 1, 2020 | 02:59 PM
cloudf56's Avatar
cloudf56
Hello all! I recently purchased my 2015 Mini Cooper S f56 a little over a year ago and have put around 25-30k miles on it traveling back and forth from college and home so the car is around 100k miles. Recently I have been hearing a bit of a grinding when I left off the throttle at higher RPMS (I love hearing the pops and crackles of the exhaust). I was told that this may be caused by the lower engine mount/torque arm, and was looking into purchasing a replacement and was wondering before I do so if this is a difficult replacement. I’m a beginner to working on car and don’t want to ruin my baby. Thank you guys for the help!
Old May 9, 2020 | 03:21 PM
N0B0DY's Avatar
N0B0DY
The lower mount is easy to replace but have you checked the upper mounts?
Old May 9, 2020 | 04:51 PM
cloudf56's Avatar
cloudf56
I had the vehicle serviced and the lower engine mount was what they told me was going bad, however I did not check the upper mounts.
Old May 9, 2020 | 04:59 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
It's very possible a lower mount failed could cause that.
If you need to replace it you can get just the powerflex bushing which is a simple replacement and on sale right now. We put them in all the F56s we build as it's a good mode to reduce engine rock.
https://www.waymotorworks.com/powerf...g-f55-f56.html
Old May 10, 2020 | 02:32 PM
Arrivederci Zagato's Avatar
Arrivederci Zagato
I have the same problem as you. High revs with no throttle input yields a grinding noise. I have found that this is the result of a busted upper engine mount (situated behind the passenger's headlight). I would advise checking it out since it's a common issue with the F platform.
https://www.northamericanmotoring.co...placement.html
^This is a useful thread if you want to take the DIY route and buy the part yourself. It's not too bad of a process. Most of the difficulty stems from wiggling the mount out/in beneath the refrigerant line.
Old May 10, 2020 | 02:37 PM
cloudf56's Avatar
cloudf56
Wow, thank you! I will definitely look into this and I probably will try and go the DIY route. Did you do it yourself? I just purchased the lower engine mount, so I’ll let you know the outcome!
Old May 10, 2020 | 02:44 PM
Arrivederci Zagato
I have gotten to that engine mount before, but couldn't unbolt it from the frame as I did not have the right tools. Getting to it is easy (really just pieces of trim and 3 or 4 screws for the headlight). Getting the mount in and out and without stripping the bolts is the hard part. It should be a maximum 3 hour job if you have the correct tools. Remember to support the engine from below if you do it yourself! That thread that I linked was my go-to and is a wealth of info so be sure to consult it.
1357924680the
Jan 21, 2011 07:00 PM
everytimeidie027
Classic Mini Talk
Sep 25, 2006 02:34 PM
chows4us
Off-Topic :: Autos
20
Aug 8, 2006 06:06 AM
RCristiano
Classic Mini Talk
Jul 18, 2006 05:42 PM
minifinn
Off-Topic :: Autos
Jun 2, 2004 07:34 PM
