F55/F56 Steering wheel
Old Dec 7, 2019 | 10:56 AM
robby71's Avatar
robby71
Steering wheel
Are the steering wheels from an auto and manual both compatible?
I know the auto has cut outs on the back for the paddles but will it work on a manual car (no the paddles aren't there just the cut outs)
Old Dec 9, 2019 | 12:34 PM
Yep, they can swap. just has those cut outs for the paddles and wires for the paddles.
Old Dec 9, 2019 | 12:59 PM
robby71's Avatar
robby71
phew - just ordered it off ebay so glad it will fit
Do you know if the plastic covers on the back of my old wheel will fit over the cut outs on the back of the auto wheel?
Got it cheap but would like to make it look as it should
Old Dec 9, 2019 | 01:03 PM
6FT6's Avatar
6FT6
You mean just the covers for the cut outs or the entire back?
Old Dec 9, 2019 | 01:06 PM
The front covers are the same, the rear has the cutout for the paddles, but overall the same. You can see below what it looks like without the trim
We have the CF wheels here and they are really nice.
https://www.ecstuning.com/b-euro-imp...3/mc3-cfs~eim/
Old Dec 9, 2019 | 01:09 PM
robby71's Avatar
robby71
I was hoping the 2 covers on the back of my old wheel will fit over the cut outs on the back of the wheel.
The front is bare like in your photo so i'll swap over the controls and trim off my old wheel (standard Cooper S wheel to swap with JCW auto wheel)
Old Dec 9, 2019 | 01:41 PM
Yep,
Looks at the back picture of our EI wheel and it should match up.
Old Dec 9, 2019 | 02:08 PM
robby71's Avatar
robby71
Yep,
That's a great looking wheel
So the 2 plastic parts on the back just pop off and will fit onto an auto paddle wheel to cover the slots?
Old Dec 9, 2019 | 02:09 PM
Yep,
the skeleton of the wheel is the same. If that makes sense.
Old Dec 9, 2019 | 02:16 PM
robby71's Avatar
robby71
Great, i wasn't sure if the plastic covers on the back would come off to swap over
Here are a couple of pics of the wheel i've just bought - bare bones from an auto paddle so will swap my controls and lower trim from my old wheel and can now swap the back covers to cover the flappy paddle holes
Old Dec 9, 2019 | 02:23 PM
Yep, take the paddle cover off the one and swap it over. Let me know if you have any problems. I am here to help even if you did not buy the wheel from us.
Old Dec 9, 2019 | 02:29 PM
robby71's Avatar
robby71
Thanks, you've been a great help - i have bought parts from you in the past from my VAG days
Old Dec 9, 2019 | 02:30 PM
Cool, thanks for the continued support.
Glad to help.
Old Dec 10, 2019 | 10:47 AM
robby71's Avatar
robby71
Wheel turned up today so it'll be something to do this weekend.
Looks like i need to swap the wiring from old to nes as the auto wiring has an extra plug (unless i can use this wiring and just ignore the extra plug?)
I can remove the back cover off the wheel (large round cover) but can't see how the 2 other covers come off (the ones the paddle screw onto with the cut outs?) - they look separate though?
Old Dec 10, 2019 | 10:57 AM
swap it over on the wires to be safe,
Those can covers that hold the to the back are bonded on there, i would just leave them. They looked like they came off compared to the EI CF wheel
Old Dec 10, 2019 | 12:27 PM
robby71's Avatar
robby71
Yep, the back wont be seen when the wheel is fitted i guess
Probably cost too much in postage to UK but how much could you supply the bottom part of the wheel for with the JCW name tag as my old wheel just has the plain V shape? - item 3 in pic
Old Dec 10, 2019 | 12:30 PM
Thats the part Dont know how much it is in the UK. Add to cart with your details and it will calculate.
https://www.ecstuning.com/b-genuine-...l/32306864894/
Old Dec 10, 2019 | 12:46 PM
robby71's Avatar
robby71
:( postage costs more than the part - i'll wait until i need some more parts and band them together
Old Feb 8, 2020 | 10:41 AM
minideucecoop's Avatar
minideucecoop
Part number
I just got done using chat on ECS for how much "alteration" would need be done. They couldn't help me out ,so now I see this thread and want to order for my automatic with paddles, cruise control, radio, and phone controls. You're saying I shouldn't have any issues? Thanks in advance!
Old Feb 10, 2020 | 06:42 AM
Hello,
You can always reach out to me for the more technical issues, especially modding to work. As you can see we talked about this above.
Old Jun 23, 2020 | 09:29 AM
minideucecoop
Steering wheel installed.
I guess I won't have the paddles option anymore. The wheel actually comes with the large round plastic back, so that part doesn't need to be swapped over. That screw in what looks like a back arm panel (directly under the paddle) is for the front face plate. The arm panel where the paddles are attached isn't a panel at all. It's a rubbery section which is molded and bonded around the steering wheel arm, front to back, all one solid piece. There are no holes for the paddle wire to pass through, and no mounting points to attach the paddles. Unless someone can drill holes and router small rectangles into the back of the rubber pads, or cut up and glue on their $730 brand new steering wheel, it's probably not modification that's worth it. There's no way the finish is going to be as good as how it was made. I don't use the paddles, only the manual side of the stick, so it kind of hurts taking away the looks and functionality, even thought I don't use it. But overall the wheel is nice, about a billion times better than the stock wheel with grey stitching. Also, I didn't swap the oem wiring harness into the new wheel. The paddles use one extra wire and a ground. (It's the brown ground in the center of the metal frame.) The new wheel is wired for no paddles.
Old Jun 24, 2020 | 07:45 AM
Looks great!
Old Jul 18, 2020 | 05:48 PM
jpsjr1970's Avatar
jpsjr1970
Looks great! ECS Tuning always rocks! Question? Does it come in Alacantra w/Red Stitching?
Old Jul 19, 2020 | 04:11 AM
minideucecoop
They have the JCW wheel with alcantara but it doesn't have any carbon fiber on it.
Old Jul 20, 2020 | 10:21 AM
Yep, just stock JCW and euro impulse wheel
