F55/F56 shift knob removal ???
Old Jul 30, 2019 | 10:14 AM
jpbpe's Avatar
jpbpe
shift **** removal ???
Hi all, I'm trying to install Way Motors F56 short shifter in my 2014 Cooper. The instructions they referred me to have Step 3 = pull shift **** straight up to remove. NFW will that **** move, much less come off, so I am stuck having barely begun. Any suggestions for removing shift **** are greatly appreciated. With your help, I'll try again tomorrow...thanks...jim
Old Jul 30, 2019 | 10:21 AM
Craho's Avatar
Craho
In my 2019 6mt, you just pull like hell and it finally pops off. Mine takes the shift boot and everything off with it.
My best advice is if you punch through the sunroof after the **** finally released, you’ve gone too far...but not by much.
Old Jul 30, 2019 | 11:24 AM
vetsvette's Avatar
vetsvette
Moderator
Pop the ring loose and disconnect any plugs for electronics. Then, just pull like hell and try not to knock yourself out or remove the sunroof. That's not a joke!
Old Jul 30, 2019 | 11:27 AM
El-Grunto's Avatar
El-Grunto
Yup. Pull like hell. But like Vette said, disconnect the ring and mode selector wire first.
Old Jul 30, 2019 | 12:24 PM
jpbpe's Avatar
jpbpe
Thanks guys. I already have a hernia so I need a different approach...
Old Jul 30, 2019 | 12:26 PM
El-Grunto's Avatar
El-Grunto
Ask a friend, neighbor, or relative to rip on it? Go to a gym and ask the most jacked person there to do it? If you drive to Seattle I'll do it for you.
Old Jul 31, 2019 | 02:46 PM
ASKtheteach's Avatar
ASKtheteach
Pull up on the trim ring at the base of the shifter (3 clips hold it in place). If you have the driving mode selector switch there (green, mid, sport), unplug the connector. With the car in neutral, pull up really hard to remove the ****. Be careful, I punched myself in the nose when mine popped off.
Old Jan 29, 2020 | 04:29 PM
joemysterio's Avatar
joemysterio
Anyone have a solution on securing it back on? After I removed mine to add the Cravenspeed short shifter and pro clip, the **** went back on without an issue but now a small tug up and it pops right off. It happened to me twice already while driving, after only three short trips.
Old Jan 30, 2020 | 02:47 PM
wjones14's Avatar
wjones14
You should email Cravenspeed. They have excellent customer support and will reply to your email.
Not sure how the short shifter works, but I bought a Cravenspeed 6-speed ****. I got lucky with the stock **** since mine was not nearly as difficult to pull off as I feared it would be. But when I put the Cravenspeed **** on, at first it was pulling up - not completely popping off - but I knew it wasn't right. Emailed Cravenspeed and they told me that I must not have pushed their adapter collar down far enough on the shift lever. Sure enough, that was the problem. **** is secure now.
Old Jan 30, 2020 | 03:15 PM
Altecfenix's Avatar
Altecfenix
He's right! It might very well be resolved by adjusting the stock **** adapter. But of course hit us up and we'll see what's going on. @joemysterio shoot an email to support@cravenspeed.com if it keeps happening and we'll take care of it.
tomm9050
Dec 27, 2007 07:51 PM
jgf
Jul 8, 2006 10:00 PM
pfunk
Jan 17, 2006 12:59 PM
muy_mini
Apr 6, 2005 07:59 PM
