Interior/Exterior shift knob removal
Old Jan 12, 2006 | 12:25 AM
pfunk's Avatar
pfunk
shift **** removal
I know I am supposed to be able to yank it off but I just can't do it!!!
I have a b&m short shifter with stock ****. Just got a Whalen and try to put it on but the sucker just won't come off! Can someone help?
Old Jan 12, 2006 | 12:48 AM
SCCA's Avatar
SCCA
It will come off...just brace yourself across it,one foot in each footwell, and make sure you don't pop yourself in the nose when it comes off...it does take some serious effort, but theres no real trick to it
Old Jan 12, 2006 | 04:51 AM
jonnieoh's Avatar
jonnieoh
It is also recommended that if you have a sunroof, to open it before trying to pull the **** off. This is if you yank so hard that once it does release, your hands go flying up above your head, that you don't hit and possibly shatter the sunroof glass...
Good luck!
Old Jan 12, 2006 | 04:58 AM
MiniFr34k's Avatar
MiniFr34k
put some muscle in it.
putting it into gear also helped.
Old Jan 12, 2006 | 05:19 AM
SwingMCS03's Avatar
SwingMCS03
Put it in 2nd gear and pull like a mule.
Old Jan 12, 2006 | 06:09 AM
NMgokart's Avatar
NMgokart
Or...you could use a large crescent wrench and a 3lb sledge. Set the crescent just larger than the shifter shaft, put it under the **** and whack it from the underside with the sledge. Sunroof rules definitely apply!
Old Jan 12, 2006 | 07:47 AM
Wagnbat's Avatar
Wagnbat
It doesn't take serious muscle to get it off, but it does take some serious effort and pulling. And when it pops off, you'll likely be caught off guard, so opening the sunroof is a very good suggestion. Also a football helmet, so you don't knock yourself out. Ok, the second tip was a joke. Kinda.
Old Jan 12, 2006 | 07:51 AM
mcswrks's Avatar
mcswrks
Can you put it back on after its removed?
Old Jan 12, 2006 | 08:01 AM
FlynHawaiian's Avatar
FlynHawaiian
I just asked the dealership to do it for me :P
Old Jan 12, 2006 | 08:04 AM
goaljnky's Avatar
goaljnky
Com'on man, put your back into it...
Old Jan 12, 2006 | 08:14 AM
Doug W's Avatar
Doug W
Yes; but sometimes the little plastic snaps get a bit deformed after removing the ****, and it may come off the lever a bit easier from then on (though that could be a GOOD thing!).
Old Jan 12, 2006 | 09:47 AM
LombardStreet's Avatar
LombardStreet
Moderator
I stumbled across a web page somewhere that suggested (as above) putting on foot in each footwell, putting the shift lever in 2nd gear, and then (here's the different part) reaching over and around the **** with one hand so your palm is facing away from you and your thumb and forefinger are under the ****. Then reach around in the same fashion with the other hand, so both hands are gripping the **** with your thumbs down, wrists crossed, and your palms facing each other.
This sounds pretty awkward (and I haven't tried it), but it would seem to reduce the chance you'd hit your face or your sunroof with the **** when it comes flying off. (Rearview mirror, maybe?)
Sorry I didn't bookmark the page. I think it was a page about Z3s or some other BMW model. (Don't blame me if you break something, please!)
Old Jan 12, 2006 | 10:37 AM
goaljnky's Avatar
goaljnky
I have to say, that there was very minimal risk of breaking the sunroof when I was removing the **** in my convertible....
Old Jan 12, 2006 | 04:07 PM
jonnieoh's Avatar
jonnieoh
wear a mouth guard too!
Old Jan 12, 2006 | 04:59 PM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
Pfunk...if it's still on when you get to AMVIV, I'll remove it for you.
Old Jan 12, 2006 | 05:30 PM
kenchan's Avatar
kenchan
i just grabbed it (both hands) put my arms on my knees and pushed up with my
ankles.
Old Jan 12, 2006 | 05:36 PM
ncdave's Avatar
ncdave
It actually does get easier to remove after the first time - just like lots of other things.
Old Jan 12, 2006 | 05:51 PM
Electric Shock's Avatar
Electric Shock
Hmm - maybe I did it the wrong way but it worked for me. I used one of those rubber strap wrenches - and jiggled and twisted the **** off. No damage of any kind.
I don't even have my whalen yet. I expect it any day now. But as soon as I ordered mine I went out to see if I could get my stock **** off.
Old Jan 12, 2006 | 07:03 PM
SwingMCS03's Avatar
SwingMCS03
You can do it!
Old Jan 12, 2006 | 07:16 PM
J0kER's Avatar
J0kER
while pullin' up, twist the **** back and forth, it will open up the prongs on the shift rod. also helps if its real warm out.
Old Jan 13, 2006 | 06:19 AM
Doug W's Avatar
Doug W
Excellent point about heat!
A hair drier on high, aimed at the bottom of the **** for a few minutes, should help dramatically.
Old Jan 13, 2006 | 11:36 AM
Motor On's Avatar
Motor On
I put mine in 4th, and sitting in the druvers seat just pulled it off, does take a little bit of work though, I'll have to try the hair drier next time
Old Jan 17, 2006 | 12:59 PM
pfunk's Avatar
pfunk
Thanks guys. Hair dryer really helped. After wiggling for a while, it finally came off!
I know I am little late in the game here but I love the Whalen!!
chandler_vt
Apr 29, 2017 08:08 AM
cawwwtun
May 3, 2016 08:03 AM
jziran
Aug 24, 2015 04:50 PM
WayMotorWorks
Aug 19, 2015 08:04 PM
